12-14-2011 11:44 PM - edited 03-16-2019 08:33 AM
hi all,
Having small question , if cucm is synchornized with ldap , if ldap server is not working all the users will come to inactive (perge) state ?
kindly help me on this
thanks in advance
karthik
Solved! Go to Solution.
12-15-2011 01:41 AM
Hi karthik,
Users will not be purged in the scenario you describe. If the LDAP sync fails the users in CUCM will remain active indefinitely.
The only instance in which users will be purged in CUCM is when they are deleted in LDAP and a successful sync takes place.
12-15-2011 01:41 AM
Hi karthik,
12-15-2011 03:49 AM
Thanks for your reply
Karthik
