Surendra BG Thu, 12/15/2011 - 05:45
Yes its is supported!! i just tried just for you
Please dont forget to rate the usefull posts!!
Surendra
wireless wlc Sun, 01/27/2013 - 07:04
hi Surendra,
  Its supported, but does it work like AND or OR ? cos if you have a client which is NOT added in mac filter list but has the WPA PSK key set will be able to connect. Is this expected behaviour ? I am expecting the client should pass both mac filter check and PSK check before allowing the client to connect ?
regards
Joe
Scott Fella Sun, 01/27/2013 - 08:04
No... It's both or none.
sreejith_r Sun, 01/27/2013 - 14:30
Yes, First it will check for the MAC Address , if MAC is not there it will drop the request.
If it finds the mac address it will check for the PSK.
If either of one fails, the request will be dropped.
