Warning message
ASA with iphone and certs
Dec 15th, 2011
I have an ASA running 8.4.1.  VPN using anyconnect/smartcards (microsoft certs) works without any issues.
I'm trying to get iphones to be able to VPN with certs/anyconnect and it works (sort of)....
    After I import the USER cert (.pfx) onto the iphone, the connection works but I'd need...
          1. The cert to prompt me for a password (right now, after the import password, no password is required; just connect)
          2.  The ASA/Splunk logs can't identify who is actually VPN'd in... Username says "USERS"
Suggestions?
Jeff Van Houten Thu, 12/15/2011 - 22:01
  • Silver, 250 points or more
At a minimum you need the mobile device license on the Asa which is separate from the any connect user licenses.
