12-15-2011 11:11 AM - edited 03-04-2019 02:39 PM
Purchased and configured 2951 router based on Telco specs that required T3/DS3 card with coax connection for MPLS. When telco showed up to install DS3 they handed me a UTP copper connection.... Can I use one of the Gigabit ethernet connections on the 2951 as my MPLS interface into the provider's cloud?
Rick
Solved! Go to Solution.
12-15-2011 12:09 PM
Rick
Unfortunately no you can not use a Gigabit Ethernet if the telco interface is T3/DS3. The copper connection may have the same form factor but the protocols in use are significantly different between Ethernet and T3/DS3.
Rick
12-15-2011 12:09 PM
Rick
Rick
12-15-2011 01:43 PM
Thanks Rick. I really appreciate the help.
