Warning message
Agent pim warnings
Dec 16th, 2011
ICM version: 7.5
There are lot of warnings coming on the CUCM PIM1 from which one warning is mentioned below:
11:00:52:741 pg1B-pim1 Trace: [  2492]Call::FindLocked by CID: 2130716800 failed to match call. 11:00:52:741 pg1B-pim1 Trace: [  2492]TelephonyDriver::SendUniversalFailureConf - Error 13 Per Error 10137 (PERERR_UNKNOWN) Unknown Peripheral Error 11:00:52:741 pg1B-pim1 Trace: [  2492]DeskLinkPeripheral::CSTAUniversalFailureConfEvent - CSTA Error 13 Per Error 10137 (PERERR_UNKNOWN) Unknown Peripheral Error 11:00:52:741 pg1B-pim1 Trace: [  2492]CSTAUniversalFailureConfEvent - TPServices::CSTAUniversalFailureConfEvent Invo11:00:52:741 pg1B-pim1 Trace: [  2492]Call::FindLocked by CID: 2130716800 failed to match call. 11:00:52:741 pg1B-pim1 Trace: [  2492]TelephonyDriver::SendUniversalFailureConf - Error 13 Per Error 10137 (PERERR_UNKNOWN) Unknown Peripheral Error 11:00:52:741 pg1B-pim1 Trace: [  2492]DeskLinkPeripheral::CSTAUniversalFailureConfEvent - CSTA Error 13 Per Error 10137 (PERERR_UNKNOWN) Unknown Peripheral Error 11:00:52:741 pg1B-pim1 Trace: [  2492]CSTAUniversalFailureConfEvent - TPServices::CSTAUniversalFailureConfEvent Invo
In Error codes Pererr_unkwown description shows this is due to space limitations, but I didn't get it.
Any idea about these warnings????
Muhammad Fahad Raza
david.macias Fri, 12/16/2011 - 06:23
  • Blue, 1500 points or more
Looks like you have a couple of things wrong based on the screenshot.  Can you restart the pim and post the beginning of the log, that should show you what errors/warnings come up when the pim initiates.
david
Related Content
