WCS - Lobby Ambassador
Answered Question
Dec 16th, 2011
Hello all,
My WCS is configured with the help of a location several campus and buildings in it. When i´m trying to create an ambassador account i want to give him permissions for creating guest users accounts on just a campus with several buildings.
My main problem is that when i´m trying to create this account i have to limit this to a single building but i want to select all buildings.
Is there a way for me to select all buldings in a campus?
Correct Answer by ramkris2 about 5 years 4 months ago
Looks like the mapping within the hierarchy was missed. I would suggest opening a TAC service request so if required a bug can be filed to address this.
Overall Rating: 5 (1 ratings)
Stephen Rodriguez Fri, 12/16/2011 - 05:21
  • Purple, 4500 points or more
When you login to the WCS do you see all the buildings?
David Santos Fri, 12/16/2011 - 05:23
Yes,
but that is a drop list, force me to select just one per campus and i want to select all buildings in a campus.
Stephen Rodriguez Fri, 12/16/2011 - 05:46
Ok so how is the guest WLAN setup?  Does it exist on all the WLC?  When you choose the buildings for the lobby admin, you can only select the controllers that have the guest WLAN.
You may want to do a refresh config from all of the WLC, and then check again which building(s) you can select.
HTH,
Steve
Please remember to rate helpful posts or to mark the question as answered so that it can be found later.
ramkris2 Fri, 12/16/2011 - 07:34
  • Cisco Employee,
Hi David,
Regardless of what you select the accounts are applied in the back-end based on the Controller's those AP's are associated to. For example: If AP's in building 1 & building 2 are all joined to the same WLC, even if you select just 'building 1' the account will be pushed to that WLC & the guests would be able to associate to any AP that belongs to that WLC.
So I would suggest, applying the accounts based on 'Controller list' & selecting the WLC's to which the accounts should be applied to.
Ram
David Santos Fri, 12/16/2011 - 07:55
ramkris2,
i want to enable guest accounts based on buildings and not on controllers. I want to limit the guest account users based on campus and not on controllers.
I have two WISMs (4 controllers)  and the campus are distributed on the several controllers so my idea is to have the guest accounts limited to the specified campus.
so why do i want this?
I want to creater several lobby ambassador accounts to distribute to the IT Departments so that they can only create guest accounts that affect their campus and not to user that same accounts onthe others.
Stephen Rodriguez Fri, 12/16/2011 - 09:11
I was going to say you could use Virtual Domains to accomplish this, but thinking about it, it won't quite work the way you want.
So with the Virtual Domains, you would assign WLC and Maps to the Domain, and then the admin would only see the WLC and Maps they are assigned.
However, if I'm reading you correctly, they use shared hardware currently.  So they would all have access to the same WLC to create the users on.
You could play this game, if the other IT Departments/Campuses were to purchase there own WLC for the guest access, and each use a different SSID.  Then you could create the VD, so the lobby admin could only see the WLC for their guest SSID, and shazam!
HTH,
Steve
David Santos Fri, 12/16/2011 - 09:32
Stephen Rodriguez,
i think i´m just complicating this to much. My cenario is this:
a) 8 Campus and each one with several buildings.
b) I want a lobby account for each campus.
c) i´ve got two 6500 and a WISM on each.
d) WCS in the configuration lobby account, in the lobby ambassador defaults tab forces me to select ONLY a single building in the campus and i want to select all
Can this be done? How can i select all buildings in the campus for the lobby accounts ?
ramkris2 Fri, 12/16/2011 - 10:36
  • Cisco Employee,
David,
The option for "All buidlings" is not present though it should be, like it has for "All floors" within a building. I verified this with the latest WCS(7.0.220.0) available.
Ram
Correct Answer
ramkris2 Fri, 12/16/2011 - 13:49
  • Cisco Employee,
Related Content
Trending Topics - Security & Network
