Warning message
simple nat help
Dec 16th, 2011
HI all
can you please look in to my config and say the natting is correct.
int gi 0/0
ip address 10.10.45.1 255.255.255.0
ip nat inside
int  gi 0/1
ip address 99.89.99.99 255.255.255.248
ip nat outside
int gi 0/2
ip address 101.100.188.130 255.255.255.248
ip nat outside
access-list 10 permit 10.10.45.0 0.0.0.255
ip nat inside sourcelist 10 int fa 0/1 overload
or
#ip nat pool XXX <start ip> <end ip> netmask  255.255.255.248
#ip nat inside source list 10 XXX overload
srikanth
Overall Rating: 5 (3 ratings)
viswamin Fri, 12/16/2011 - 05:17
  • Cisco Employee,
Hi Srikanth,
Looks like we have a problem in this command
as we dont have fa 0/1 in the shared config. so it should be gi0/1 or gig0/2 instead of fa0/1
Rest of the configurations looks good to me
-Vijay
srikanth ath Fri, 12/16/2011 - 05:20
Hi vijay
thanks for the quick reply. and thats my mistake fa 0/1 should be gi 0/1
and can i go with this nat policy whats the diffence between 1 and 2 below
1.
ip nat inside sourcelist 10 int gi 0/1 overload
2.
#ip nat pool XXX netmask  255.255.255.248
srikanth
Latchum Naidu Fri, 12/16/2011 - 05:24
  • Blue, 1500 points or more
Hi srikanth,
Some of the fiels are incorrect in your config.
See the below config which fits you....
int gi 0/0
ip nat inside
int  gi 0/1
ip nat outside
int gi 0/2
ip nat outside
ip nat inside source route-map nonat interface GigabitEthernet0/1 overload
route-map nonat permit 10
match ip address NONAT
ip access-list extended NONAT
permit ip 10.10.15.0 0.0.0.255 any
Please rate the helpfull posts.
Naidu.
viswamin Fri, 12/16/2011 - 05:48
  • Cisco Employee,
Hi Naidu.,
I doubt if the above said config works.
You had defined an access list
which will match the source address on 10.10.15.0/24 network. This will not have any match.
so the natting itself will not happen. I guess the ACL shuld permit 10.10.45.0 instead of 10.10.15.0
Also, the NAT can be performed with ACL's alone instead of writing a route map. so we cannot claim that the config that srikanth had is incorrect. its just other way of matching the IP to NAT.
-Vijay
Latchum Naidu Sun, 12/18/2011 - 23:16
Hi Vijay,
I just put an example numbers, so the Srikanth need to change those number according to his requirement.
I knew that NAT can be perform with ACL's, the idea behind route-map are more flexible than ACL.
I thought to list what all the filelds can be put in more effecient way.
Hope I clear you...
Naidu.
