Warning message
GNS3 and problem with VLANs on c3700
Dec 17th, 2011
I have some problems with setup VLANs in GNS3.
The network topology is as on picture:
with following details:
- router c3700 for CME with VOICE IOS c3725-adventerprisek9-mz.124-15.T7.bin
- router c3700 with NM-16ESW module for simulating switch
- 2x Cisco IP Communicator in VLAN 20
- 2x PC in VLAN 10
The problem is starting during setup VLANs on router c3700 with NM-16ESW module.
When I try to set following:
SW1(config)#vlan 10
SW1(config-vlan)#name DATA
SW1(config-vlan)#vlan 20
SW1(config-vlan)#name VOICE
SW1(config)#interface range fastEthernet 1/0 - 1
SW1(config-if-range)#switchport mode access
SW1(config-if-range)#switchport access vlan 10
SW1(config-if-range)#switchport voice vlan 20
SW1(config-if-range)#spanning-tree portfast
SW1(config-if-range)#end
The VLAN 10 and VLAN 20 are assigned to ports fa 1/0 fa 1/1 as stated below.
In this situation PC1 from VLAN 10 can not ping PC2 in VLAN 20:
SW1#show vlan-switch
VLAN Name                             Status    Ports
1    default                          active    Fa1/2, Fa1/3, Fa1/4, Fa1/5
                                                Fa1/6, Fa1/7, Fa1/8, Fa1/9
                                                Fa1/11, Fa1/12, Fa1/13, Fa1/14
                                                Fa1/15
10   DATA                             active    Fa1/0, Fa1/1
20   VOICE                            active    Fa1/0, Fa1/1
1002 fddi-default                     act/unsup
1003 token-ring-default               act/unsup
1004 fddinet-default                  act/unsup
1005 trnet-default                    act/unsup
I tried the same scenario with Packet Tracer and there it works flawlessly.
In this situation PC1 from VLAN 10 can ping PC2 in VLAN 20:
SW1#show vlan
1    default                          active    Fa0/4, Fa0/5, Fa0/6, Fa0/7
                                                Fa0/8, Fa0/9, Fa0/10, Fa0/11
                                                Fa0/12, Fa0/13, Fa0/14, Fa0/15
                                                Fa0/16, Fa0/17, Fa0/18, Fa0/19
                                                Fa0/20, Fa0/21, Fa0/22, Fa0/23
                                                Fa0/24, Gig1/1, Gig1/2
10   DATA                             active    Fa0/2, Fa0/3
20   VOICE                            active
The subinterfaces on CME router are configured properly on same way in GNS3 and Packet Tracer.
What do you suggest?
Best regards,
Tony
alitadir Sat, 12/17/2011 - 02:06
Hi Tony, I think you have to configure the switch port which connected to the CME router as a trunk. If you configured it properly, it will work.
interface fasthernet 1/10
switchport mode trunk
Hope this helps
Ali TADIR
marton225 Sat, 12/17/2011 - 03:38
I have already set trunk on fa1/10 of SW1 interface.
My PC is on 192.168.1.0 network, and it is place from where I am trying to realize ping toward GNS3.
Network that connects CIPC and SW1 is on 192.168.1.0 /24 network, and it is same network between my PC and GNS3.
Ping normally works to 192.168.1.10 subinterface, but it doesn't work toward 192.168.2.10 subinterface.
If I change network between PC and GNS3 to 192.168.2.0 /24 (then it become same network between CIPC and SW1).
Then I need to put switchport access to vlan 20,  and in this case I am able to ping 192.168.2.10 subinterface, but not 192.168.1.10 subinterface
SW1(config-if-range)#switchport access vlan 20
SW1(config-if-range)#switchport voice vlan 10
For more clearly understanding below are startup config from CME router and SW1 switch:
CME startup config:
version 12.4
hostname CME
interface FastEthernet0/0
no ip address
speed 100
full-duplex
interface FastEthernet0/0.10
description DATA VLAN
encapsulation dot1Q 10
ip address 192.168.1.10 255.255.255.0
interface FastEthernet0/0.20
description VOICE VLAN
encapsulation dot1Q 20
ip address 192.168.2.10 255.255.255.0
interface Serial0/0
no ip address
shutdown
no fair-queue
clock rate 2000000
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/1
no ip address
shutdown
clock rate 2000000
interface Serial0/2
no ip address
shutdown
clock rate 2000000
ip forward-protocol nd
ip http server
no ip http secure-server
control-plane
line con 0
line aux 0
line vty 0 4
end
SW1 startup config:
version 12.4
hostname SW1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0
no ip address
shutdown
no fair-queue
clock rate 2000000
no ip address
shutdown
duplex auto
speed auto
interface Serial0/1
no ip address
shutdown
clock rate 2000000
interface Serial0/2
no ip address
shutdown
clock rate 2000000
interface FastEthernet1/0
interface FastEthernet1/1
interface FastEthernet1/2
interface FastEthernet1/3
interface FastEthernet1/4
interface FastEthernet1/5
interface FastEthernet1/6
interface FastEthernet1/7
interface FastEthernet1/8
interface FastEthernet1/9
interface FastEthernet1/10
description CONNECTION TO THE CME ROUTER
duplex full
speed 100
interface FastEthernet1/11
interface FastEthernet1/12
interface FastEthernet1/13
interface FastEthernet1/14
interface FastEthernet1/15
interface Vlan1
no ip address
ip http server
control-plane
line con 0
line aux 0
line vty 0 4
end
Best regards,
Tony
