WPA2-Personal on Cisco1811w
Answered Question
Dec 18th, 2011
Try and try, we have been unable to use WPA2 (Pre-shared Key aka Personal) to connect to a Cisco1811w.
This works fine if we turn off encryption.
What we see in debug messages is (debug dot11 station connection failure).
*Dec 18 21:17:05.041 CST: Client c417.fed5.8522 failed: Dot1x MIC mismatch
*Dec 18 21:17:05.137 CST: Client c417.fed5.8522 failed: Dot1x MIC mismatch
*Dec 18 21:17:05.237 CST: Client c417.fed5.8522 failed: Dot1x MIC mismatch
*Dec 18 21:17:05.337 CST: %DOT11-7-AUTH_FAILED: Station c417.fed5.8522 Authentication failed
We have tried an 8 character and 11 character pre-shared key. Same results. Why are we getting Dot1x MIC mismatch?
Can someone please help us find what is wrong?
Cisco IOS Software, C181X Software (C181X-ADVENTERPRISEK9-M), Version 12.4(24)T3
! config parts
aaa new-model
aaa authentication login default local
aaa authentication login VPN local
aaa authorization exec default local
aaa authorization network VPN local
dot11 ssid ACDinternet
vlan 98
authentication open
authentication key-management wpa
guest-mode
wpa-psk ascii 7 010013165D0E141F205E5A10
interface Dot11Radio0
no ip address
encryption vlan 98 mode ciphers aes-ccm tkip
ssid ACDinternet
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
no cdp enable
interface Dot11Radio0.98
encapsulation dot1Q 98
no cdp enable
bridge-group 98
bridge-group 98 subscriber-loop-control
bridge-group 98 spanning-disabled
bridge-group 98 block-unknown-source
no bridge-group 98 source-learning
no bridge-group 98 unicast-flooding
bridge irb
bridge 98 protocol ieee
bridge 98 route ip
interface BVI98
ip address 192.168.98.1 255.255.255.0
ip access-group 198 in
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1452
end
Thanks for any support you can provide!
Correct Answer by Scott Fella about 5 years 7 months ago
I understand it's a Cisco router, but the commands are the same for the AP. Try to manually configure the client for wpa/tkip and see if your client connects. If it does, then the configuration is not for WPA2. Usually if that is not an option, it means the radio/ios doesn't support wpa2.
Scott Fella
Sent from my iPhone
Overall Rating: 5 (2 ratings)
Scott Fella Sun, 12/18/2011 - 19:26
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
Looks like your setup is for wpa/tkip.  Have you tried that to see if it works.  It also depends if your hardware supports wpa2.
Example:
1240AG> enable
1240AG# configure terminal
1240AG (config)# interface dot11radio 0
1240AG (config-if)# encryption vlan 30 mode ciphers aes-ccm
1240AG (config-if)# ssid Admin
1240AG (config-if-ssid)# vlan 30
1240AG (config-if-ssid)# authentication open
1240AG (config-if-ssid)# authentication key-management wpa version 2
1240AG (config-if-ssid)# wpa-psk ascii your-key-here
http://networking-newbie.blogspot.com/2008/11/configuring-wpa-and-wpa2-on-cisco.html
Kris Thompson Mon, 12/19/2011 - 07:44
This is not Aironet hardware, but a Cisco router with Dot11Radio interfaces. It appears the configuration model has changed, SSID parameters are NOT set under the interface, but the SSID configuration is put under "dot11 ssid" mode.
This can be seen here. There are no commands under the interface SSID.
  aus-hym-rtr01(config-if-ssid)#vlan ?
  % Unrecognized command
  aus-hym-rtr01(config-if-ssid)#?
  ssid configuration commands:
Under SSID configuration, "version 2" is not an option. I beleive it is the default.
   aus-hym-rtr01(config-ssid)#authen key-management wpa ?
     optional  allow legacy clients
The configuration seems correct for WPA2 and AES (although, we also added TKIP to the ciphers in case that made a difference, but it did not). The wireless client we were testing from was showing WPA2 and AES.
The configuration looks correct after a LOT of research. However, we continue to get the Dot1x MIC Mismatch.
Perhaps this is a known defect?
Correct Answer
Scott Fella Mon, 12/19/2011 - 07:49
  • Hall of Fame,
    2017 Wireless
Scott Fella
Sent from my iPhone
blakekrone Mon, 12/19/2011 - 08:03
  • Silver, 250 points or more
Your configuration like Scott has pointed out is for WPA, not WPA2. What you have configured is WPA-PSK with AES, which some clients might have issues with. I would recommend changing the encryption to simply be TKIP and setup your client to do WPA-PSK/TKIP.
In order to get WPA2-PSK/AES you need to change the following:
vlan 98
authentication open
guest-mode
no ip address
If it won't take the command for
authentication key-management wpa version 2 then that means you can't do WPAv2 on that unit with the current code.
Kris Thompson Mon, 12/19/2011 - 19:02
slight typo above. Should be:
   int dot11radio
      encrypt vlan 98 mode ciphers tkip
blakekrone Mon, 12/19/2011 - 19:05
yes that is true for WPA/TKIP. The config I was showing was for WPA2/AES if it was supported.
Scott Fella Mon, 12/19/2011 - 07:59
  • Hall of Fame,
    2017 Wireless
Kris,
I have an 871w that doesn't support wpa2 an a 1941w that does support wpa2.
blakekrone Mon, 12/19/2011 - 11:07
Glad you got it working somewhat. Please do rate the posts if you find them helpful.
As for the WPAv2, if you have Smartnet I would advise opening a TAC case, this might be a case of simply needing the correct IOS level to enable WPAv2.
Related Content
Trending Topics - Security & Network
