Warning message
CUCM RS232 port usage
Dec 19th, 2011
Hi Folks, Yes I know tha the serial port of server was there to connect to a 3rd part voicemail system (not that I ever saw one) but what if I need to use it for something else - can it be done? I may well have a requirement for users to initiate sending some character string out of the RS232 port by pressing say an URL fast dial button on a phone.
paolo bevilacqua Mon, 12/19/2011 - 07:06
  • Hall of Fame,
    Founding Member
You can develop an application for that, but I'm not sure you will be able to use CM server serial port.
