Warning message
[Cisco AnyConnect] Certificate authentication on RADIUS
Answered Question
Dec 19th, 2011
I'm using certificate authentication and LDAP authorization and it works fine.
Now, I want to centralize authentication and authorization on RADIUS server (Cisco ACS in my case)
In connection profile, we have 3 authentication methods:
  • AAA: I can choose RADIUS or LDAP server group --> User is prompted for credentials user/password
  • Certificate: I can't choose AAA Server Group... --> User must provide certificate
  • Both: I can choose RADIUS or LDAP --> User is prompted for credentials user/password and user must provide certificate
If I choose certificate authentication methods, I can't delegate authentication and authorization to RADIUS server.
Is there a solution for delegating certificate authentication to RADIUS?
I have different authorization rules for each VPN Connection profile
Can ASA send VPN connection profile to RADIUS? (in RADIUS attribute...)
Thanks for your help,
Patrick
Correct Answer by Marcin Latosiewicz about 4 years 6 months ago
Patrick,
The key thing in deployments using WLC is that supplicant on client  can talk EAP (including EAP-TLS) so the AAA server can authenticate the certificate.
In case of Anyconnect, or old IPsec client there is no way to send the full cert to AAA server (either not implmented/redundant from client's point of view, or not in standard).
IOS gives you also a possibility to perform PKI authorization call:
http://www.cisco.com/en/US/docs/ios-xml/ios/sec_conn_pki/configuration/15-2mt/sec-cfg-auth-rev-cert.html
AFAIR no similar mechanism exists on ASA.
M.
Overall Rating: 0 (1 ratings)
dmh Sun, 09/23/2012 - 03:16
Hi Patrick,
I've hit the same issue and came across your post. Have you worked out a solution?
If you can't centralise it you don't have a log of all the connections. Wireless certificate authentication works over RADIUS so ideally AnyConnect should too.
Thanks, Darren
l-mathews Mon, 12/28/2015 - 07:05
I have similar issue.  Anyconnect vpn users can't authenticate with radius; it defaults to local. I haven't specified local nor do I want to. This is to two-factor authentication; anyconnect vpn users has certificate installed locally. Certificate installed from AD, pushed down by group policy
I tested aaa radius-server authentication and it was successful.
I have the config posted by Javier
tunnel-group AnyConnect general-attributes
     authentication-server-group RADIUS
tunnel-group AnyConnect webvpn-attributes
     authentication aaa certificate
Any ideas? Am I missing something?
Also what does the certificate-map-group command do
Javier Portuguez Sun, 09/23/2012 - 05:27
  • Red, 2250 points or more
Hi Patrick,
What exactly does not work?
You can have something like this:
Doing this you will use RADIUS to authenticate your AD users and a certificate as a two-factor authentication method.
Please let me know.
Thanks.
Portu.
Patrick Tran Mon, 09/24/2012 - 00:23
@Darren, I contacted Cisco reseller support and there is no solution...
@Javier, If I choose certificate authentication, I cant delegate authentication to RADIUS Server. ASA checks certificate validity...
As Darren said, Cisco WLC can delegate certificate authentication to RADIUS but Cisco ASA cant.
Best regards,
Patrick
Correct Answer
Marcin Latosiewicz Tue, 01/29/2013 - 08:30
  • Cisco Employee,
Patrick,
M.
srue Tue, 01/29/2013 - 06:55
  • Blue, 1500 points or more
Did anyone try Portu's response?
I'm trying to do the same thing except using ISE as the radius servers.
Thanks.
