Warning message
Cisco unity conneciton 8.6
Dec 19th, 2011
In cisco unity connection cluster 8.6
When we are shuting down the unity connection publisher server from cluster, The voicemail is not working,
When we press the voicemail mesaage button, Phones are rinning its not playing the unity prompt.
when the publisher online everything its work fine.
As per the cluster senario , If one of the server will down all the services will work like voicemail auto attendant etc...
Please can you tell me where is a problem.
Overall Rating: 5 (1 ratings)
Rob Huffman Mon, 12/19/2011 - 06:15
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi there,
Could be one of these bugs;
CSCtt22188 - Delay accessing subscriber when publisher is down
Description
Symptom:
Delay before Connection asks for PIN
Conditions:
User tries to access Connection SUB while PUB is down
Workaround:
None
Details
1st Found-in:                          (2)
8.6, 8.5(1)
More
Less
Status:
Fixed
Last Modified:
Dec 04,2011
Known Affected Versions:
More
Less
Fixed-in:                          (6)
8.6(2.21007.1), 8.6(2)ES11, 8.6(1.21018.1)
8.6(1)ES15, 8.5(1.14046.1), 8.5(1)ES72
More
Less
Product:
Cisco Unity Connection
Platform:
Dependent
Severity:
3 - moderate
Customer Reported:                          (7)
CSCtu18594 : Sign-in delay on sub when pub is down in cluster
Symptom:
When the Unity Connection Publisher is down, and the Subscriber is the one
taking calls, then the users might experience delay while signing in.
Conditions:
Unity Connection 8.5(1) SU2
Workaround:
Check the Engg Notes for workaround
Cheers!
Rob
Tommer Catlin Tue, 12/20/2011 - 08:31
  • Green, 3000 points or more
If you are using a SIP trunk, this is true.  We have a customer that is expierencing up to 1.5 minute delay.   if you are using SCCP integration, there is no delay.    The upgrade did fix the issue though... so on new deployments, better to go with 8.6 if you can for Connection.    +5 for Rob!
Related Content
