12-19-2011 07:24 AM - edited 03-21-2019 05:05 AM
I have a Smart CallConnector server setup and fuctional. The Advanced Client works fine.
Want to setup the Operator Console but the only install that I have found is the Stand-Alone version. Is this the version that I should use? It is installed on a PC, but I cannot figure out how to set it up to use the server.
Thanks!
12-19-2011 01:24 PM
yes champ, you need the client version. Uninstall the standalone version and get the client version and install
12-19-2011 01:48 PM
Is there another place to get the software? The download site connected to the community only lists the Stand Alone version and we did not purchase support with the software.
