C2901 VWIC3-1MFT-T1/E1 frame relay
Dec 19th, 2011
IOS  15.1(4)M1.
I am trying to setup my new 2901 running  15.1(4)M1 for frame realy via a VWIC3-1MFT-T1/E1 card.  Now I have set up plenty of frame relay connections via older serial cards, but I just cannot find any documentation on how to do this on one of the new VWIC3-1MFT-T1/E1s.  None of the commands I am used to seem to even exist.  None of the
encapsulation frame-relay ietf
frame-relay interface-dlci 16 ietf
seems to be there.  Could anyone point me to a document that would outline how to configure the card in IOS 15?
Joerg
darren.g Mon, 12/19/2011 - 15:05
  • Silver, 250 points or more
joerggrau wrote:
IOS  15.1(4)M1.
Joerg
Joerg
You need to configure a channel group containing the number of channels you have (depends on if you're an E1 or T1) and assign it to a serial interface.
See the following
http://www.cisco.com/en/US/docs/routers/access/1700/software/feature/guide/t1e11700.html#wp64656
Cheers.
Related Content
