Warning message
VG224 FXS Port Problem
Dec 20th, 2011
Hi All,'
Please find the below debug output for voice application in VG224 device.
01HW239102#debug voice application stcapp port 2/15
stcapp port debugging is on for 2/15
01HW239102#
01HW239102#
01HW239102#
01HW239102#
*Jun 30 17:13:40.427: 2/15   : stcapp_register_device
*Jun 30 17:13:40.427: 2/15   :     Device not in ready state!
*Jun 30 17:13:41.427: 2/15   : stcapp_register_device
*Jun 30 17:13:41.427: 2/15   :     Device not in ready state!
*Jun 30 17:13:42.427: 2/15   : stcapp_register_device
*Jun 30 17:13:42.427: 2/15   :     Device not in ready state!
*Jun 30 17:13:43.427: 2/15   : stcapp_register_device
And the FXS ports doesn't gets registered in CUCM.
01HW239102#sh stc dev voice-port 2/15
Port Identifier:  2/15
Device Type:      ALG
Device Id:        -1
Device Name:      AN2414AEFD9940F
Device Security Mode : None
Modem Capability: None
Device State:     OOS
Diagnostic:       Phone Offhook
Directory Number: Not Registered
Dial Peer(s):     25
Dialtone after remote onhook feature: not activated
Busytone after remote onhook feature: not activated
Last Event:       STCAPP_CC_EV_CALL_SETUP_IND
Line State:       UNREGISTERED
Line Mode:        CALL_BASIC
Hook State:       ONHOOK
mwi:              DISABLE
vmwi:             OFF
PLAR:             DISABLE
Callback State:   DISABLED
Number of CCBs:   0
Global call info:
    Total CCB count      = 1
    Total call leg count = 2
01HW239102#
Please anyone suggest me a solution for this problem.Thanks..
Loganathan S
CCNP (R&S).
Overall Rating: 5 (1 ratings)
paolo bevilacqua Tue, 12/20/2011 - 05:52
  • Hall of Fame,
    Founding Member
Check config on both VG and CM.
Adrian Saavedra Tue, 12/20/2011 - 06:34
  • Gold, 750 points or more
Hello Loganathan,
If config on VG224 and CallManager is fine, then I usually fix this registration issues doing a no stcapp and stcapp in global configuration mode.
Hope it helps, please rate if it does.
Kind regards,
- Adrian.
s.loganathan Tue, 12/20/2011 - 18:45
Hello Adrian,
That doesn't help me to resolve the problem.Even i tried reloading the VG224,but didn't helped me to register that port alone.Please anyone suggest me a solution.
Loganathan S
CCNP R&S
corygreene Tue, 01/03/2012 - 08:33
I too am having this same issue that just started today. I have verified both CM and the VG config, no changes since installation. If I reboot the VG224 CM shows the port registered momentarily then goes back to an unregistered state. I also noticed that the port is not displayed at all in the output of the sh sccp command. Any help on this would be appreciated, thanks!
maharris Tue, 01/03/2012 - 12:12
  • Silver, 250 points or more
Well, if it is only one port, and reboot of gateway does not help, maybe something in CUCM is hung up - you could either try reboot of server, or if you have a cluster, make a special cm group to point it at a different server, see if it comes up there.
Mary Beth
Sadaseeven Saminaden Wed, 12/19/2012 - 01:54
Have you tried changing your analog phone.
I had a phone with a hardware issue, in the sense that even when you place the handset on the hook, I refused to go into on-hook state.
Got the same kind of error, rebooted VG and cluster. Issue stayed same.
I replaced the phone with a working one, then it worked..
