Cisco WAAS Upgrade on WAE-7371-K9
Dec 21st, 2011
Hi there
I'm trying to upgrade this device WAE-7371-K9 to the newest image that has been released because i'm getting a licensing error, and apperently a image upgrade could solf the problem.
This is the problem that I'm encountering:
License Name   Status      Activation Date Activated By
Transport      not active
Enterprise     active      12/21/2011      mtn
Video          not active
Accelerator     Licensed        Config State    Operational State
cifs            Yes             Enabled         Shutdown
epm             Yes             Enabled         Shutdown
http            Yes             Enabled         Shutdown
mapi            Yes             Disabled        Shutdown
nfs             Yes             Enabled         Shutdown
ssl             Yes             Enabled         Shutdown
video           No              Enabled         Shutdown
CIFS:
   Policy Engine Config Item            Value
   State                                Not Registered
   Default Action                       Use Policy
   Connection Limit                     0
   Effective Limit                      0
   Keepalive timeout                    0.0 seconds
So I was told if I upgrade the IOS it should fix it, now i'm stuck with this issue when I'm trying to upgrade from waas-accelerator-4.4.1.12-k9.bin to waas-accelerator-4.4.3c.9-k9.bin i get this:
But I restarted the device and still no luck.
FYI - My experience and knowledge is limited on WAAS devices, only getting to know them now... Use to R&S.
Bhavin Yadav Wed, 12/21/2011 - 12:02
  • Cisco Employee,
Hi Andre,
Couple of things that can help you on what's going on with this WAE.
Please use following commands to get clear idea on the status of WAE.
WAE7341-1#sh  reload
No Reload Scheduled
WAE7341-1#sh version last
Saved version is WAAS 4.1.7a-b10, built on 11:13:05 Aug 16 2010 by cnbuild
It can be restored by running restore rollback command
WAE7341-1#sh version pending
No pending version
This will tell you if the WAE has got new image / installing it or any other status.
if nothing works, try realoding if you can.
if reload does nto fix it, you may want to follow recovery process:
http://www.cisco.com/en/US/docs/app_ntwk_services/waas/waas/v441/configuration/guide/maint.html#wp1105252
Good luck.
andrehbosch Thu, 12/22/2011 - 23:18
Hi Bhavin
I tried the following:
sabf-0004-centraloff-wae-1#sh reload
No Reload Scheduled
sabf-0004-centraloff-wae-1#sh version last
sabf-0004-centraloff-wae-1#sh version pending
No pending version
nothing works, even reloaded it,
Going to do your last step, but need to schedule downtime, Will post the results as soon as I have it.
andrehbosch Thu, 12/29/2011 - 21:33
I have Upgraded the image, and still I get the following:
sabf-0004-centraloff-wae-1#sh accelerator
sabf-0004-centraloff-wae-1#sh alarms
Critical Alarms:
        Alarm ID                 Module/Submodule               Instance
   1 svcdisabled               nodemgr                      sodre_stats
Major Alarms:
None
Minor Alarms:
None
Cisco Wide Area Application Services Software (WAAS)
Copyright (c) 1999-2011 by Cisco Systems, Inc.
Cisco Wide Area Application Services Software Release 4.4.3c (build b9 Nov 29 2011)
Version: oe7371-4.4.3c.9
Compiled 16:12:50 Nov 29 2011 by damaster
Device Id: 00:1a:64:c9:a2:0c
System was restarted on Fri Dec 30 07:00:47 2011.
The system has been up for 17 minutes, 50 seconds.
andrehbosch Thu, 12/29/2011 - 22:01
I have also tried the follwing:
sabf-0004-centraloff-wae-1#copy ftp install 10.111.192.55 software/ waas-accelerator-4.4.3c.9-k9.bin
Enter username for remote ftp server: mtn
Enter password for remote ftp server:
Initiating FTP download...
printing one # per 1MB downloaded
now downloading waas-accelerator-4.4.3c.9-k9.bin
Sending: USER mtn
Cisco Wide Area Application Services Central Manager
FTP server (Version wu-2.7.0(1) Fri May 27 09:30:04 PDT 2011) ready.
Password required for *******.
Sending: PASS **********************
User mtn logged in.  Access restrictions apply.
Sending: TYPE I
Type set to I.
Sending: PASV
Entering Passive Mode (10,111,192,55,95,187)
Sending: CWD software/
CWD command successful.
Sending PASV
Entering Passive Mode (10,111,192,55,186,110)
Sending: RETR waas-accelerator-4.4.3c.9-k9.bin
Opening BINARY mode data connection for waas-accelerator-4.4.3c.9-k9.bin (203154818 bytes).
Reclaiming unused flash safe state sectors ...SSMGR RETURNING: 4 (Success)
Done.
System should be running properly before upgrade begins.
It seems system software was not correctly installed on
this device. Please, reload the device and retry the software install.
Upgrade failed.
andrehbosch Thu, 12/29/2011 - 23:18
Got it working with the follwoing steps:
On wae:
disk delete-data-partitions
reload
*re-install software
copy ftp install
reload
on central manager
go to device->activation
unselect Activate
Then select Replaceable
on device
cms recover identity default
once done
on central manager
unselect replaceable and select activate again
on device
conf t
cms enable
