ACE: URL redirect - not working
Dec 21st, 2011
I've to do url redirection from port 80 to port 443. I've following configured:
rserver redirect url.test.com-rd
  webhost-redirection https://url.test.com/
  inservice
serverfarm redirect url.test.com:80
  description url.test.com - port 80 redirect ***
  rserver url.test.com-rd
    inservice
class-map match-any url.test.com:80
  2 match virtual-address 192.168.1. tcp eq www
policy-map type loadbalance first-match url.test.com:80
  class class-default
    serverfarm url.test.com:80
  policy-map multi-match LOAD_BALANCE
   class url.test.com:80
    loadbalance vip inservice
    loadbalance policy url.test.com:80
    loadbalance vip icmp-reply active
with above configuration, ACE is redirection port 80 to port 443 but it also rewrites the header.  i.e. ACE send me to
"https://url.test.com/" if I type "http://url.test.com/abc" in the browser. It should have redirected to  "https://url.test.com/abc" ( it shouldn't have removed "/abc")
could you advice how to accomplish it.
Thanks in advance...
pablo.nxh Wed, 12/21/2011 - 13:39
Hi Gavin,
You must add "%p" after the forward slash, like this:
  webhost-redirection https://url.test.com/%p
  inservice
That shoould do it
__ __
Pablo
gavin han Wed, 12/21/2011 - 15:21
thanks pablo. but that isn't expected response. redirected url shows the load balanced server. i.e. for the following serverfarm of port 443:
serverfarm host url.test.com:443
  description url.test.com - Port 7777 ***
  failaction purge
  probe url.test.com:7777
  rserver server1.test.com 7777
    inservice
redirected url comes as "http://server1.test.com:7777/abc/" ...instead of what I expect .i.e. i expect "
https://url.test.com/abc/"
pablo.nxh Wed, 12/21/2011 - 16:20
Hi Gavin,
In this case your backend servers have configured this redirection in the HTTP server itself i.e apache, IIS, etc...
I don't know all the details behind your site but you need to decide whether this is required (you may implement URL rewrite on response for that host header) or you can just remove it and let the ACE do all the redirection job.
__ __
Pablo
