12-21-2011 01:43 PM
How can I configure VPN connection between Cisco RV042 and Fritz!box 7170?
I can establish VPN channel with Linksys RV042 with firmware 1.3.12.6-tm.
When I set the same setting to Cisco RV042 (firmware v4.0.2.08-tm) VPN channel is not established.
12-21-2011 11:39 PM
check the fritxbox website, there are various config examples
05-27-2017 08:10 AM
Did you solved the problem in VPN connection Fritz Box to RV042?
05-28-2017 03:57 AM
No.
After a few months my Fritz broke down and I changed the router to another one.
From this time I used TP-Link WR-842ND, Cisco RV180W and now TP-Link Archer C7 with OpenWRT instaled.
All of this routers I configured to establish VPN tunnel between routers.
05-28-2017 04:03 AM
TNX Walter
It seems to be an impossible mission to establish VPN with Fritz Box and RV042
