AQM version 8.5.2 issue with desktop recoirding
Dec 21st, 2011
Hi Experts...
I have integrated my AQM with cucm (alreday checked and implemented as per compatibility matrix).
I have done the initial config and workflow etc as per the available guide
But the issue is that when i record call from supervisor desktop the same is not getting saved(recording) to teh QM server which has all the services installed in a standalone server .
I have gone through loggs and found the entioned error and i guess because of this reason the same is not getting uploaded .
" ERROR QMUC2002 Java exception(Proxy Connection failed.)."
Need your support in finding the cause of this issue.
RC
geomansour Wed, 02/22/2012 - 01:09
Hi i wanted to ask you if you have found the solution to this problem as i am facing it with one of my installation.
I will be waiting your reply.
Thank you & Best Regards,
Aaron Harrison Wed, 02/22/2012 - 01:24
  • Community Spotlight Award,
    Member's Choice, May 2015
I would first check basic things like name resolution; ensure that your servers are all resolvable via DNS.
Failing that post up your log files for analysis
Aaron
geomansour Wed, 02/22/2012 - 04:11
Hi Guys,
the problem was from the SQL version, when i installed standard edition everything worked correctly.
Thank you all for your prompt reply.
