Warning message
CME TO CME, background noise on calls one WAN
Dec 22nd, 2011
i have a CME in SiteA and another CME in SiteB, when call made across site, we experience noise and i have checked the codec used which is G.729. please what might be the problem.
Overall Rating: 5 (1 ratings)
acampbell Thu, 12/22/2011 - 14:45
  • Green, 3000 points or more
You will need to have QOS configured accross the WAN
Alex
rammany19 Thu, 12/22/2011 - 15:31
Please can I see a sample config for the IP WAN qos?
acampbell Fri, 12/23/2011 - 01:25
To back up what Ronak has sent. (+5  Ronak)
Remember if your WAN is via a Service providers network PEs,MPLS etc etc you need to
ask/buy QOS from them as well as setting up your own CE routers etc.
It is a big subject which needs to be considered before deploying any WAN based IPT/UC solution.
Alex
rammany19 Sat, 12/24/2011 - 14:33
Hello
i have checked the QOS SRND guide but didnt find what suit my need, please can i get an example config for the IP WAN QOS for point to point link below 768, do i need to enable cRTP on the link?
please help as this noise is getting too much, thanks.
Related Content
