12-22-2011 02:31 PM - edited 03-04-2019 02:43 PM
I'm trying to replace a ASA 5505 with a Cisco 2801 w/ security bundle.
I have gone through a pretty basic set up of configuring what I could and letting the Cisco Config Prof do the security audit to lock it down. I have everything working just fine except for the bandwidth.
As soon as I plug the router in it seems to give all the bandwidth to one computer and the rest of the campus slows down to a crawl.
I turned on "fair-queue" and even tried the QoS wizard in CCP, but it seems like thats if you want to prioritize voice over data - which we aren't running VOIP so I don't need.
I am completely missing something and could really use some help.
12-23-2011 03:13 AM
Post your config for review.
12-23-2011 04:48 AM
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname
boot-start-marker
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
logging buffered 51200 debugging
logging console critical
enable secret 5
aaa new-model
aaa authentication login local_authen local
aaa authorization exec local_author local
aaa session-id common
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
no ip source-route
ip cef
ip port-map pptp port tcp 1723 list 4
ip inspect name CCP_LOW cuseeme
ip inspect name CCP_LOW dns
ip inspect name CCP_LOW ftp
ip inspect name CCP_LOW h323
ip inspect name CCP_LOW sip
ip inspect name CCP_LOW https
ip inspect name CCP_LOW icmp
ip inspect name CCP_LOW imap
ip inspect name CCP_LOW pop3
ip inspect name CCP_LOW netshow
ip inspect name CCP_LOW rcmd
ip inspect name CCP_LOW realaudio
ip inspect name CCP_LOW rtsp
ip inspect name CCP_LOW esmtp
ip inspect name CCP_LOW sqlnet
ip inspect name CCP_LOW streamworks
ip inspect name CCP_LOW tftp
ip inspect name CCP_LOW tcp
ip inspect name CCP_LOW udp
ip inspect name CCP_LOW vdolive
ip inspect name CCP_LOW http urlfilter
ip inspect name sdm_ins_in_100 cuseeme
ip inspect name sdm_ins_in_100 dns
ip inspect name sdm_ins_in_100 ftp
ip inspect name sdm_ins_in_100 h323
ip inspect name sdm_ins_in_100 sip
ip inspect name sdm_ins_in_100 https
ip inspect name sdm_ins_in_100 icmp
ip inspect name sdm_ins_in_100 imap
ip inspect name sdm_ins_in_100 pop3
ip inspect name sdm_ins_in_100 netshow
ip inspect name sdm_ins_in_100 rcmd
ip inspect name sdm_ins_in_100 realaudio
ip inspect name sdm_ins_in_100 rtsp
ip inspect name sdm_ins_in_100 esmtp
ip inspect name sdm_ins_in_100 sqlnet
ip inspect name sdm_ins_in_100 streamworks
ip inspect name sdm_ins_in_100 tftp
ip inspect name sdm_ins_in_100 tcp
ip inspect name sdm_ins_in_100 udp
ip inspect name sdm_ins_in_100 vdolive
ip tcp synwait-time 10
ip flow-cache timeout active 1
no ip bootp server
ip name-server 10.10.10.13
ip urlfilter server vendor n2h2 10.10.10.60
ip ssh time-out 60
ip ssh authentication-retries 2
ip ssh version 2
crypto pki trustpoint TP-self-signed-2736186409
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2736186409
revocation-check none
rsakeypair TP-self-signed-2736186409
crypto pki certificate chain TP-self-signed-2736186409
certificate self-signed 01
quit
username
interface Null0
no ip unreachables
interface FastEthernet0/0
description $ETH-WAN$$FW_OUTSIDE$
ip address
ip access-group 107 in
ip verify unicast reverse-path
no ip redirects
no ip unreachables
no ip proxy-arp
ip inspect sdm_ins_in_100 in
ip inspect CCP_LOW out
ip flow ingress
ip nat outside
ip virtual-reassembly
ip route-cache flow
duplex auto
speed auto
fair-queue
no mop enabled
interface FastEthernet0/1
description $FW_INSIDE$
ip address 10.10.10.2 255.255.0.0
ip access-group 106 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow egress
ip nat inside
ip route-cache flow
duplex auto
speed auto
fair-queue
no mop enabled
ip default-gateway
ip classless
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0
ip flow-export source FastEthernet0/1
ip flow-export version 5
ip flow-export destination 10.10.10.11 9996
ip flow-top-talkers
top 10
sort-by bytes
cache-timeout 60000
ip http server
ip http access-class 2
ip http secure-server
ip nat inside source list 5 interface FastEthernet0/0 overload
ip nat inside source static 10.10.10.10
logging trap debugging
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 10.10.0.0 0.0.255.255
access-list 2 remark HTTP Access-class list
access-list 2 remark CCP_ACL Category=1
access-list 2 permit 10.10.0.0 0.0.255.255
access-list 2 deny any
access-list 3 remark CCP_ACL Category=2
access-list 3 permit 10.10.0.0 0.0.255.255
access-list 4 remark CCP_ACL Category=1
access-list 4 permit 10.10.10.10
access-list 5 remark CCP_ACL Category=2
access-list 5 permit 10.10.0.0 0.0.255.255
access-list 100 remark auto generated by CCP firewall configuration
access-list 100 remark CCP_ACL Category=1
access-list 100 deny ip
access-list 100 deny ip host 255.255.255.255 any
access-list 100 deny ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip any any
access-list 106 remark auto generated by CCP firewall configuration
access-list 106 remark CCP_ACL Category=1
access-list 106 deny ip
access-list 106 deny ip host 255.255.255.255 any
access-list 106 deny ip 127.0.0.0 0.255.255.255 any
access-list 106 permit ip any any
access-list 107 remark auto generated by CCP firewall configuration
access-list 107 remark CCP_ACL Category=1
access-list 107 permit udp any host
access-list 107 permit tcp any host
access-list 107 remark GRE
access-list 107 permit gre any host
access-list 107 deny ip 10.10.0.0 0.0.255.255 any
access-list 107 permit icmp any host
access-list 107 deny ip 10.0.0.0 0.255.255.255 any
access-list 107 deny ip 172.16.0.0 0.15.255.255 any
access-list 107 deny ip 192.168.0.0 0.0.255.255 any
access-list 107 deny ip 127.0.0.0 0.255.255.255 any
access-list 107 deny ip host 255.255.255.255 any
access-list 107 deny ip host 0.0.0.0 any
access-list 107 deny ip any any log
snmp-server ifindex persist
no cdp run
control-plane
banner motd ^C
You are accessing $(hostname)
Unauthorized access prohibited
^C
line con 0
logging synchronous
login authentication local_authen
transport output telnet
line aux 0
line vty 0 4
logging synchronous
transport input ssh
end
12-23-2011 10:17 AM
Not sure what you mean by "all the bandwidth goes to one computer"
but...one thing I spotted was your static route points to an interface.
read the link below, and consider making the change.
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a00800ef7b2.shtml
12-23-2011 11:34 AM
Well, there are a few things that happen.
First, I get reports for multiple people that someone is hogging all the bandwidth. On the other hand I have had other people say that their internet hasn't slowed down and is fine.
I then go and check the flows and it shows one local IP using almost all of the bandwidth for small tasks, such as email recovery. For instance, I turned it on yesterday and a computer of someone who wasn't here immediately spiked on the logs with a source of 1e100.net (which I'm assuming was just gmail as we use Google Apps).
12-23-2011 12:13 PM
It would be helpful to have some knowledge of the topology behind the router.
Just an editorial here, I would use the ASA for security, and the 2801 for routing and not combine the two functions.
start looking at traffic policing, it may meet your needs regarding overconsumption of resources.
with any luck some one else will pick up this thread next week. I'm on vacation.
12-23-2011 02:00 PM
More info: My current topology is ISP - ASA - Core Switch
I need to replace the ASA as it is not passing PCI compliance.
I changed the static route as per your first reply.
After working on it again today I think instead of giving away too much bandwidth it may be not giving enough.
I plugged it in and ran a speedtest on my phone via wifi and it only was giving me .05Mbps download, but close to 4.0Mbps upload. There is hardly anyone here because of the impending holiday and I checked the flows and no one even got close to peaking at our max of 4.5Mbps download.
12-23-2011 07:50 PM
The ASA is by far a better firewall than a 2800 because it is a firewall by design. It is PCI compliant (and generally considered more secure than IOS) assuming your old configuration was correct. That being said IOS inspection is a much slower firewall. I would remove all ACLs and the CBAC both inbound and out and test the speed. If your results are still bad I would set the interfaces to manual speed and duplex on all network devices. If you results are better, I would try to use zone based firewall or go back to the ASA.
