Memory upgrade for MCS 7816-I3
Dec 26th, 2011
Hhello, I'm wanting to increase the memory of a mcs 7816-I3, but purchase a kingston memory and does not turn on.
I'm must use only the IBM memories to work? Do you have any model of memory to suggest?
Sorry my english
Overall Rating: 4 (1 ratings)
Leonardo Tadeu Mon, 12/26/2011 - 15:17
  • Blue, 1500 points or more
Hello Jean,
Did you check the data sheet
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/ps5748/ps378/data_sheet_c78-478928.html
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/ps5748/ps378/prod_brochure0900aecd8062a4f9.html
The kingston memory meet this requirements of the datasheet?
If these memory mett this requirements you can open a case on Cisco PDI to see if they recommend any model of memory..
Other thing this server is a IBM machine you can check on IBM documentation to see if this server accept other fabricant memories...
Rate this post if  is useful to you
Leonardo Santana
Jaime Valencia Mon, 12/26/2011 - 16:02
  • Cisco Employee,
  • Hall of Fame,
    2011
"If these memory mett this requirements you can open a case on Cisco PDI to see if they recommend any model of memory.."
We do not handle this kind of queries, this is something you would need to discuss with pre-sales. We only handle technical queries on the UC products but specs and what HW/memory to buy from Cisco or any other vendor is beyond our scope.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
Leonardo Tadeu Tue, 12/27/2011 - 03:35
Sorry Java i didnt know, thanks for the info!!!!!
Jean you can check on IBM and see the memories supported.
Did take a look on the server manual?
jguandalini Tue, 12/27/2011 - 02:38
The memory what we buy was:
Kingston: KVR667D2S4P5/2G
2GB 667MHz DDR2 ECC Reg with Parity CL5 DIMM Single Rank
