Question about BGP routing tshooting.
Dec 27th, 2011
Hello there,
Have a problem at job and couldnt understant what is going on with routing between vrfs.
Just a quick question.
From base perspective: How could it be, if I can ping ip address using specified source - and it's successful. So we can assume that there is connectivity between them. But i cant understood why the ping in reverse is failing... Both points (for this example loopbacks) are ping enabled.
for ilustration:  Domain (A): ping X with source Z = successfull
        Domain (B) reverese:ping Z with source X = unsuccesfull                 it the ping from one side is successful (replies can make way to come back we should asume all is ok, but...)
Overall Rating: 3 (1 ratings)
Reza Sharifi Tue, 12/27/2011 - 13:05
  • Cisco Designated VIP,
    2017 LAN
are you sourcing each ping from the right VRF?
can you post your config from both routers?
what type of devices are you using and what is the design look like?
kajatonas88 Tue, 12/27/2011 - 13:17
hey man, sorry i cant, cause it's complex ISP network, but i can assure that there is no filters blocking icmps... and yes im sourcing right. Actualy this is not Cisco devices, but it's very simmilar  - Juniper ERXs. I just need some hints where i can continue troubleshooting
Reza Sharifi Tue, 12/27/2011 - 13:37
    2017 LAN
Have you configured the same RT on both routers.
sample config:
instance-type vrf;
interface fe-0/0/2.0;
route-distinguisher 10.0.3.3:1;
vrf-target target:65412:100;
