Problems with 2901 hsrvp
Dec 27th, 2011
I have 2 x 2901 in a hsrvp setup.
so I have some wan ports attached to both of these routers and I have 1 port from each router attached 1 a sw (switches in clustered mode). and 1 port attach to each other.
The ports from the router to the switch and each other are part of vlan1 and I have hsrp configured on vlan1
interface Vlan1
description to firewall
ip address a.b.c.252 mask
standby 0 ip a.b.c.254
standby 0 preempt
standby 0 authentication md5 key-string 7 THISISSOMETHIG
standby 0 name internet
interface Vlan1
ip address a.b.c.253 mask
standby 0 preempt
my problem is when i log into the standby router I can't ping the VIP a.b.c.254
standby seems to be working.
Alex
Overall Rating: 2 (1 ratings)
Reza Sharifi Tue, 12/27/2011 - 17:10
Hi Alex,
Can you set a priority for the master switch and test again?
example:
standby 2 priority 110
also the group range is from 1 to 255.  Can you try a different group number between 1 and 255?
Alex Samad Tue, 12/27/2011 - 17:16
I actually have, sorry I cut and pasted from the slave router
primary
interface Vlan1
ip address a.b.c.d.253 255.255.255.0
standby 0 ip a.b.c.d.254
standby 0 priority 105
standby 0 preempt
standby 0 authentication md5 key-string 7 SOMETHING
sho standby
Vlan1 - Group 0
  State is Active
    1 state change, last state change 38w4d
  Virtual IP address is a.b.c.254
  Active virtual MAC address is 0000.0c07.ac00
    Local virtual MAC address is 0000.0c07.ac00 (v1 default)
  Hello time 3 sec, hold time 10 sec
    Next hello sent in 2.544 secs
  Authentication MD5, key-string
  Preemption enabled
  Active router is local
  Standby router is a.b.c.252, priority 100 (expires in 10.000 sec)
  Priority 105 (configured 105)
  Group name is "internet" (cfgd)
backup router
interface Vlan1
ip address a.b.c.252 255.255.255.0
standby 0 preempt
standby 0 authentication md5 key-string 7 SMOETHING
show standby
Vlan1 - Group 0
  State is Standby
    4 state changes, last state change 1d03h
    Next hello sent in 2.448 secs
  Preemption enabled
  Active router is a.b.c.253, priority 105 (expires in 9.360 sec)
  Standby router is local
  Priority 100 (default 100)
so ping from primary to .254 work
ping from secondard to 254 times out ....
gfcisco31 Tue, 12/27/2011 - 18:04
Many things can cause such behaviour...
Let`s try the most common one first.
Check wether both routers are listening to 224.0.0.2 (.102 is its hsrp v2), to do that issue the command "sh ip interface" on both routers.
I would suggest to remove the config and apply again, in case you suspect they are not hearing each other, also you can try to ping the MCAST address to see who responds the icmp echo request.
hope this helps
Please, rate useful posts.
Alex Samad Tue, 12/27/2011 - 18:12
sh ip interface
shows me vlan1 on both routers has
224.0.0.2 associated with it
I tried pinging the 224.0.0.2 address and I got replies from the not only the local addresses, but also the wan addresses attached to the router ??
I don't believe that the routers are not hearing the heartbeats.
So i can ping the .254 address from primary router and from another device except from the the secondary router..
but it means any traffic coming in on the secondary can't ping .254
Alex Samad Tue, 12/27/2011 - 18:34
i presume you mean
show arp
and see if the mac address is in the table.. it is and its the correct one
same on the primary
Alex Samad Tue, 12/27/2011 - 18:55
Not sure if that is the same problem I am having.
So except for the standby router. All other devices on the ethernet segment can ping .254 and they can ping the real address of the routers (pri & sec).
pri can ping .254 .253 .252
but sec can only ping .253 .252 (the real addresses of the routers...
Alex
gaurav nunia Tue, 12/27/2011 - 20:12
Hi Alex,
here's more you can try :
on the standby router.
"sh ip route x.x.x.254" , see if recognises the address.
check the output of
access-list 101 permit icmp any any
debug ip packet detail 101
end
ping x.x.x.254
see if the output gives any clues- see if its getting routed or not,
also, check whether there is any ACL blocking udp 1985,
Alex Samad Tue, 12/27/2011 - 20:33
sh ip rou
show me that the router believes it is on vlan1 directly connected (the right info)
Q) dont I have to attach 101 to an interface ? in my case vlan1
and isn't there an implied deny any any at the end of the list
tried it any way
025026: Dec 28 15:23:26 AEDT: IP: s=a.b.c.252 (local), d=a.b.c.254, len 100, local feature
025027: Dec 28 15:23:26 AEDT:     ICMP type=8, code=0, Policy Routing(3), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
025028: Dec 28 15:23:26 AEDT: FIBipv4-packet-proc: route packet from (local) src a.b.c.252 dst a.b.c.254
025029: Dec 28 15:23:26 AEDT: FIBfwd-proc: packet routed by adj to Vlan1 a.b.c.254
025030: Dec 28 15:23:26 AEDT: FIBipv4-packet-proc: packet routing succeeded
025031: Dec 28 15:23:26 AEDT: IP: s=a.b.c.252 (local), d=a.b.c.254 (Vlan1), len 100, sending
025032: Dec 28 15:23:26 AEDT:     ICMP type=8, code=0
025033: Dec 28 15:23:26 AEDT: IP: s=a.b.c.252 (local), d=a.b.c.254 (Vlan1), len 100, output feature
025034: Dec 28 15:23:26 AEDT:     ICMP type=8, code=0, Post-Ingress-NetFlow(62), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
025035: Dec 28 15:23:26 AEDT: IP: s=a.b.c.252 (local), d=a.b.c.254 (Vlan1), len 100, output feature
025036: Dec 28 15:23:26 AEDT:     ICMP type=8, code=0, Post-Input-Flexible-NetFlow(73), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
025037: Dec 28 15:23:26 AEDT: IP: s=a.b.c.252 (local), d=a.b.c.254 (Vlan1), len 100, sending full packet
025038: Dec 28 15:23:26 AEDT:     ICMP type=8, code=0
025040: Dec 28 15:23:27 AEDT:  IP: s=a.b.c.253, d=224.0.0.2, pak 2A16FD60 consumed in input feature , packet consumed, MCI Check(73), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE.
025041: Dec 28 15:23:28 AEDT: IP: s=a.b.c.252 (local), d=a.b.c.254, len 100, local feature
025042: Dec 28 15:23:28 AEDT:     ICMP type=8, code=0, Policy Routing(3), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
025043: Dec 28 15:23:28 AEDT: FIBipv4-packet-proc: route packet from (local) src a.b.c.252 dst a.b.c.254
025044: Dec 28 15:23:28 AEDT: FIBfwd-proc: packet routed by adj to Vlan1 a.b.c.254
025045: Dec 28 15:23:28 AEDT: FIBipv4-packet-proc: packet routing succeeded
025046: Dec 28 15:23:28 AEDT: IP: s=a.b.c.252 (local), d=a.b.c.254 (Vlan1), len 100, sending
025047: Dec 28 15:23:28 AEDT:     ICMP type=8, code=0
025048: Dec 28 15:23:28 AEDT: IP: s=a.b.c.252 (local), d=a.b.c.254 (Vlan1), len 100, output feature
025049: Dec 28 15:23:28 AEDT:     ICMP type=8, code=0, Post-Ingress-NetFlow(62), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
025050: Dec 28 15:23:28 AEDT: IP: s=a.b.c.252 (local), d=a.b.c.254 (Vlan1), len 100, output feature
025051: Dec 28 15:23:28 AEDT:     ICMP type=8, code=0, Post-Input-Flexible-NetFlow(73), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
025052: Dec 28 15:23:28 AEDT: IP: s=a.b.c.252 (local), d=a.b.c.254 (Vlan1), len 100, sending full packet
025053: Dec 28 15:23:28 AEDT:     ICMP type=8, code=0.
025054: Dec 28 15:23:30 AEDT:  IP: s=a.b.c.253, d=224.0.0.2, pak 2A866DF8 consumed in input feature , packet consumed, MCI Check(73), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
025055: Dec 28 15:23:30 AEDT: IP: s=a.b.c.252 (local), d=a.b.c.254, len 100, local feature
025056: Dec 28 15:23:30 AEDT:     ICMP type=8, code=0, Policy Routing(3), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
025057: Dec 28 15:23:30 AEDT: FIBipv4-packet-proc: route packet from (local) src a.b.c.252 dst a.b.c.254
025058: Dec 28 15:23:30 AEDT: FIBfwd-proc: packet routed by adj to Vlan1 a.b.c.254
025059: Dec 28 15:23:30 AEDT: FIBipv4-packet-proc: packet routing succeeded
seems to be working (sending packets from the sec, will try from the pri)
i don't see it turn on up the pri, i tried pinging the real address .253 and it showed up...
gaurav nunia Tue, 12/27/2011 - 21:49
A.  yes there is a implicit deny, as we are only interested in seeing the ICMP debug, and we dont need to apply it on any interface, as we are not filtering any incoming or outgoing traffic, but the debug output only.
kmothukuri Tue, 12/27/2011 - 22:22
Hi ,
issue the command Clear mac-address table dynamic and check it once.
With Rgds,
M Satish Kumar
Alex Samad Wed, 12/28/2011 - 14:29
clear max didn't fix anything but it got me looking at the arp table as well.
standby#sh arp
Protocol  Address          Age (min)  Hardware Addr   Type   Interface
Internet  a.b.c.1           210   d0d0.fd5b.c5bd  ARPA   Vlan1
Internet  a.b.c.2            29   d0d0.fd5b.c5bd  ARPA   Vlan1
Internet  a.b.c.4           192   d0d0.fd5b.c5bd  ARPA   Vlan1
Internet  a.b.c.7           126   d0d0.fd5b.c5bd  ARPA   Vlan1
Internet  a.b.c.9           167   d0d0.fd5b.c5bd  ARPA   Vlan1
Internet  a.b.c.10          155   d0d0.fd5b.c5bd  ARPA   Vlan1
Internet  a.b.c.12          112   d0d0.fd5b.c5bd  ARPA   Vlan1
Internet  a.b.c.13          171   d0d0.fd5b.c5bd  ARPA   Vlan1
Internet  a.b.c.15          174   d0d0.fd5b.c5bd  ARPA   Vlan1
Internet  a.b.c.99           50   d0d0.fd5b.c5bd  ARPA   Vlan1
Internet  a.b.c.127          33   d0d0.fd5b.c5bd  ARPA   Vlan1
Internet  a.b.c.129         193   d0d0.fd5b.c5bd  ARPA   Vlan1
Internet  a.b.c.199          38   d0d0.fd5b.c5bd  ARPA   Vlan1
Internet  a.b.c.250          18   d0d0.fd5b.c5bd  ARPA   Vlan1
Internet  a.b.c.251          35   d0d0.fd99.079b  ARPA   Vlan1
Internet  a.b.c.252           -   c471.fe78.4923  ARPA   Vlan1
Internet  a.b.c.253           0   588d.09bb.9b5b  ARPA   Vlan1
Internet  a.b.c.254          60   0000.0c07.ac00  ARPA   Vlan1
standby#show mac-address-table
EHWIC Slot: 0
Destination Address     Address Type    VLAN    Destination Port
c471.fe78.4923          Self               1    Vlan1
d0d0.fd5b.c5bd          Dynamic            1    GigabitEthernet0/0/0
d0d0.fd99.079b          Dynamic            1    GigabitEthernet0/0/3
0000.0c07.ac00          Dynamic            1    GigabitEthernet0/0/0
588d.09bb.9b5b          Dynamic            1    GigabitEthernet0/0/0
d0d0.fd94.c628          Dynamic            1    GigabitEthernet0/0/0
standby#sh vlan-switch
VLAN Name                             Status    Ports
1    default                          active    Gi0/0/0, Gi0/0/2, Gi0/0/3
VLAN Type  SAID       MTU   Parent RingNo BridgeNo Stp  BrdgMode Trans1 Trans2
1    enet  100001     1500  -      -      -        -    -        1002   1003
so gi0/0/0 is direct attach cable to primary router
so gi0/0/3 is attached to the sw (stacked switch this to one the other router to the other switch)
so gi0/0/2 not connected
it looks all okay...
EDIT -> all this is from the standby router
ebarticel Wed, 12/28/2011 - 00:48
I think you should check the authentication as well and maybe have a delay timer configured with preempt command
Hope it helps
Eugen
Alex Samad Wed, 12/28/2011 - 14:31
Pretty sure authentication is okay, they heartbeats seem to be working and not timing out. also for the brief period I had one authenticated and one not authenticated I received errors in my syslog, which went away once I reconfigured the second interface.
as for the delay time
not sure what it is nor how it will help me ping the vip from the standby router
ebarticel Wed, 12/28/2011 - 18:38
The delay time is for the primary to know how long to wait to become primary again, usually is greater than default to give enough time for routing protocol to converge (bgp takes a bit longer than ospf or eigrp).
I am thinking that you should change priority on the secondary to become primary for a while,this will associate mac address of secondary with VIP, because at the moment the primary doesn't know where to send the ping replies. The secondary MAC address is associated with IP address of interface but not with VIP in the primary MAC table.
Other option is to create a static mapping on the primary for secondary MAC and VIP.
I hope this helps
Eugen
ebarticel Wed, 12/28/2011 - 18:45
add on to previous message...
this is entry for secondary on your primary
The primary needs to have an entry for the
c471.fe78.4923 to be associated with a.b.c.254 as well
If you make secondary primary for a while then primary will learn and asociated the MAC with VIP as well
Alex Samad Wed, 12/28/2011 - 18:52
Okay I am lost on what you are trying to say is the problem and what the potential fix might be.
if i ignore the standby router, I can ping .254 from other devices, for ex the firewall and from the internet (as long as its not routed over the standby router).
I can ping from the primary to the standby using the fixed addresses (.253, .252)  and vis versa, what I can't do is ping from the standby to the VIP (which is on the primary).
I did a packet debug which showed that the packet was actually leavin the router on the right interface (I believe)
Alex Samad Wed, 12/28/2011 - 18:47
>>The delay time is for the primary to know how long to wait to become primary again, usually is greater than default to give enough time for routing protocol >>to converge (bgp takes a bit longer than ospf or eigrp).
okay I will have to look at this once I have solved this problem.
>>I am thinking that you should change priority on the secondary to become primary for a while,this will associate mac address of secondary with VIP, >>because at the moment the primary doesn't know where to send the ping replies. The secondary MAC address is associated with IP address of interface >>but not with VIP in the primary MAC table.
??? I didn't actually show the mac table on the primary router.  but  why it think this is not the case is
primary                                    standby
a.b.c.253                              a.b.c.252
from
a.b.c.253 i can ping a.b.c.252
a.b.c.252 i can ping a.b.c.253
a.b.c.253 i can ping a.b.c.254
I can't ping a.b.c.254 from a.b.c.252
so from this I can presume that primary can ping standby.
as this is production stuff I don't want to push over VIP.
This is actually all part of testing the redundancy and to see if it works as advertised so currently I don't have faith in it actually working . I see not reason for it not to but I don't see any reason for it not to be able to ping 254 from 252 either
I don't get this, why would I want to hard code routing for a floating VIP ?  and what would it do when the VIP exist on the local router ?
Alex
ebarticel Wed, 12/28/2011 - 19:34
The static mapping is just to verify that there is redundancy and you will be able to test pings from secondary.
If it is a live environment, i guess you should test it when there is not much traffic. The only thing you should change is the priority value on secondary, wait until it becomes primary, ping the VIP from both and if all is good, just change the priority back to previous values.
Eugen
kmothukuri Wed, 12/28/2011 - 20:58
Dear Alex ,
how is the connectivity of switches..Can you provide us network diagram..
With rgds,
Satish
Alex Samad Wed, 12/28/2011 - 21:54
Does that help
The standby config is configured on vlan1, which gi0/0/ gi0/0/3 are members of
kmothukuri Wed, 12/28/2011 - 22:30
Hi ,
Can you provide us config of interfaces which are conncted to switches back to back.
Have you configured ether channel for connecting switches ?
With Rgds,
Satish
Alex Samad Wed, 12/28/2011 - 23:03
primary
interface GigabitEthernet0/0/0
description connect standby
interface GigabitEthernet0/0/3
description connect asa
interface Vlan1
ip address a.b.c.253 255.255.255.0
standby 0 ip a.b.c..254
standby 0 preempt
standby 0 authentication md5 key-string 7 something
standby
description connect primary
description connect asa5000
interface Vlan1
standby 0 preempt
Alex
kmothukuri Wed, 12/28/2011 - 23:13
Switch1G0/0/0 ---- G0/0/0 Switch2 Am i right...
Is it trunk port ? if it is trunk port which vlan's are allowed..
Alex Samad Wed, 12/28/2011 - 23:15
This is a cisco asa 5000 firewall appliance... i don't believe its trunk.. but only vlan1
Alex Samad Thu, 12/29/2011 - 01:07
?? sorry I don't think I understand ??
The 2  2901's connect by cable to each other and by cable to 2 asa5000 firewall applainces which are in a active/passive stack/cluster..
ebarticel Thu, 12/29/2011 - 02:09
Does the 2901 routers have switching module installed, or you use the default LAN interfaces to connect between routers?
Alex Samad Thu, 12/29/2011 - 02:14
are not sure.
it does have a wic in there, but not sure what command to display the module types ?
Alex
ebarticel Thu, 12/29/2011 - 02:41
if the wic has like 4-8-16 ports then is a switching module. If not then you are using the LAN interfaces
kmothukuri Thu, 12/29/2011 - 03:04
Where is the LAN ? how the systems are conncted in the LAN ..Diagram has routers and Firewall's..Do you have switches in the network ?
With Rgds,
Satish
Alex Samad Thu, 12/29/2011 - 03:16
The lan is on the other side of the firewall. But the question is why can't standby router ping the VIP ?
ebarticel Thu, 12/29/2011 - 04:00
Do you have any ip address on g0/0/0 the interface that connects the 2 routers? you will have to configure and ip address on both primary and secondary g0/0/0 interfaces and the VIP should be from same subnet. Then you will have to configure a route on the firewalls to point to the VIP. You can not configure the g0/0/3 and g0/0/0 on the same network...router will say that ip overlaps. I have created a set up similar as yours and I used subinterfaces on the routers but I had to create 5 subnets, one to each firewall, one between the routers, and 2, one from each router to Internet. It is just basic config for routers with static routing.
I have tested by shuting down serial interfae on Primary and Secondary becomes Primary, then open the interface on Primary and routers change roles again.
I will post the picture if you like
Eugen
Alex Samad Thu, 12/29/2011 - 11:12
Um  i use the vlan1 interface which binds together the interfaces so I only have to put an address on the vlan interface not all the interfaces
I don't want to use static routers. I have bgp installed and working.
i think we moving away from the the issue.
standby router can't ping the VIP. it can ping everything else.
ebarticel Thu, 12/29/2011 - 18:08
Hi Alex,
I didn't suggest you to use static routes, I have used static routes in my simulation to try to understand what the problem is and how can be solved.
    On the routers you have, you can't setup an IP address to a vlan, like you do on the switch, unless the interfaces you mentioned (g0/0/0 -g0/0/3) are part of a switching module installed on the router.
     If your g0/0/0 interfaces between the two routers are up and up, then the problem could be with bgp peer configuration.
    If interfaces g0/0/0 are up on both routers but line protocol is down then your ping goes to the firewall first and you need to check if it allows pings on outside interface( i guess it is configured as an outside the one connecting to your secondary router).
   You can use an extended ping from seondary and record the hops it goes thru, then you will know for sure which way it goes out of router.
   One other suggestion is copy the running configurations from both routers, and if you have spare 2 routers connect them together like your topology, use loopback to simulate internet and firewalls and see if it works.
This is all I can suggest now based on the info you provided.
Good luck and hope that you will get to the bottom of it.
Eugen
Alex Samad Thu, 12/29/2011 - 22:02
hi
Thanks for that, I must have missed understood you in regards to the statics!.
I can understand what you are saying about the switch module and such and I believe it is a switch module.
unfortunately I don't any spare routers
extended ping ? i have specified a source interface vlan1
still no luck.
I am still not sure its a routing issue, casue I can ping the other addresses .253 and .250 ...
I will have some time to run some more tests next year (this weekend )
A
