Warning message
Tunnel Problem from New ASA to Working ASA
Dec 27th, 2011
I have a working asa at the home office with 56 tunnels out to satellite stations.  We recently acquired another office and trying to get a tunnel working back to the home office.  The tunnel will not come up nor do I see any traffic on it using the debug isakmp or debug ipsec commands.
Here's the working config.  Assuming that the ASA in the home office is mirrored configuration for the tunnel, does anyone see anything wrong with this config?
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
shutdown
interface Ethernet0/2
shutdown
interface Ethernet0/3
shutdown
interface Ethernet0/4
shutdown
interface Ethernet0/5
shutdown
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
ip address 172.25.44.254 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address 108.232.238.84 255.255.255.248
boot system disk0:/asa824-k8.bin
boot system disk0:/asa722-k8.bin
ftp mode passive
dns domain-lookup outside
dns server-group DefaultDNS
name-server 68.94.156.1
name-server 68.94.157.1
domain-name default.domain.invalid
access-list outside_access_in extended permit tcp any host 108.214.237.84 eq 11
access-list inside_nat0_outbound extended permit ip 172.25.44.0 255.255.255.0 172.20.200.0 255.255.255.0
access-list inside_nat0_outbound extended permit ip 172.25.44.0 255.255.255.0 172.20.100.0 255.255.255.0
access-list outside_1_cryptomap extended permit ip 172.25.44.0 255.255.255.0 172.20.200.0 255.255.255.0
access-list outside_2_cryptomap extended permit ip 172.25.44.0 255.255.255.0 172.20.100.0 255.255.255.0
pager lines 24
logging enable
logging asdm errors
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-642.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 1 0.0.0.0 0.0.0.0
static (inside,outside) tcp interface 11 172.25.44.2 www netmask 255.255.255.255
access-group outside_access_in in interface outside
route outside 0.0.0.0 0.0.0.0 108.214.237.86 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
nac-policy DfltGrpPolicy-nac-framework-create nac-framework
reval-period 36000
sq-period 300
aaa authentication enable console LOCAL
aaa authentication http console LOCAL
aaa authentication serial console LOCAL
aaa authentication ssh console LOCAL
aaa authentication telnet console LOCAL
aaa authorization command LOCAL
http server enable
http 0.0.0.0 0.0.0.0 outside
http 0.0.0.0 0.0.0.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set myset esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto map outside_map 1 match address outside_1_cryptomap
crypto map outside_map 1 set peer 84.212.62.34
crypto map outside_map 1 set transform-set myset
crypto map outside_map 2 match address outside_2_cryptomap
crypto map outside_map 2 set peer 84.212.60.2
crypto map outside_map 2 set transform-set ESP-3DES-MD5
crypto map outside_map interface outside
crypto isakmp enable outside
crypto isakmp policy 1
authentication pre-share
encryption 3des
hash md5
group 2
lifetime 86400
no crypto isakmp nat-traversal
telnet timeout 5
ssh 0.0.0.0 0.0.0.0 inside
ssh 0.0.0.0 0.0.0.0 outside
ssh timeout 30
ssh version 2
console timeout 0
management-access inside
dhcpd auto_config outside
threat-detection basic-threat
threat-detection statistics access-list
threat-detection statistics tcp-intercept rate-interval 30 burst-rate 400 average-rate 200
webvpn
group-policy DfltGrpPolicy attributes
vpn-idle-timeout none
webvpn
  svc keepalive none
  svc dpd-interval client none
  svc dpd-interval gateway none
  svc compression deflate
  customization value DfltCustomization
username admin password vbv/ec7dyKqeaH4R encrypted privilege 15
tunnel-group 84.212.62.34 type ipsec-l2l
tunnel-group 84.212.62.34 ipsec-attributes
pre-shared-key *****
tunnel-group 84.212.60.2 type ipsec-l2l
tunnel-group 84.212.60.2 ipsec-attributes
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
service-policy global_policy global
prompt hostname context
call-home
profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email [email protected]
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:cdf40c985104c7afc07a6dcdd36f27e0
: end
ajay chauhan Wed, 12/28/2011 - 03:44
  • Silver, 250 points or more
This end configuration looks fine .However you need to check other end config as well. Turn on logging and initiate traffic from this end to other end and paste the logs those can also help.
Ajay
ChiCityCisco Wed, 12/28/2011 - 11:44
Thanks for the reply Ajay.  It was actually the provider not placing the ASA's IP into the DMZ.  The office uses a small business Uverse connection, and they need to provide a set of static IP's in a DMZ.
thanks,
