Warning message
ebarticel Wed, 12/28/2011 - 00:30
  • Bronze, 100 points or more
Yes it is possible if you have multihomed bgp configured. Configure the same virtual ip address on both routers. Hope this will help.
Eugen
Kishore Chennupati Wed, 12/28/2011 - 01:29
  • Gold, 750 points or more
Prashant,
It would be possible to establish bgp with the HSRP vIP. However, I woudl refrain in implementing this in a live network.
BGP is TCP based and is very fickle in that sense. Things can get pear shaped if the TCP isn't established with the stanby router. Of course if you clear the bgp session manually that would work. What I am hinting at is that  when one router ungracefully closes the  session and the other router(s) don't know to reestablish the  connection it can get ugly.
BGP is a beautifiul protocol much flexible than HSRP just because you want to save a /30 isnt much of a use. I would definelty prefer using 2 /30's and use attributes for manipulation in dual homed scenarios. Works well and scalable as well.
BTW is it mandatory to use bgp with HSRP in your network?
Kishore
