How to change a 3750G port from 4Q3T to 1P3Q3T queueing?
Answered Question
Dec 29th, 2011
On page 5-10 of the Cisco Telepresence Network Systems 2.0 Design Guide it states:
"The C3560G/3750G/E supports either 4Q3T or 1P3Q3T egress queueing configurations...it is recommended to enable 1P3Q3T egress queueing configuration, with Q1 as the PQ."
In my C3750G I do a 'show int g1/0/7 capabilities' and get this output concerning the queues:
  QoS scheduling:        rx-(not configurable on per port basis),
                                  tx-(4q3t) (3t: Two configurable values and one fixed.)
The switch is running 12.2(58)SE2
How does one change the queue structure from 4Q3T to 1P3Q3T?
Correct Answer by Adrian Saavedra about 5 years 7 months ago
You can take a look at this document:
http://www.cisco.com/en/US/docs/solutions/Enterprise/WAN_and_MAN/QoS_SRND_40/QoSCampus_40.html#wp1099352
Hope this helps, please rate if it does.
Kind regards,
- Adrian.
Overall Rating: 5 (1 ratings)
