Warning message
Private VLAN's on Nexus 2148 ?
Answered Question
Dec 30th, 2011
hi out there
I have the need for private vlans in isolated mode to backup some hosts on a secured network. We are using Cisco Nexus 5020 with the fex 2148 for copper-ports  - and I tried to implement this setup:
the isolated port:
interface Ethernet100/1/13
description AccessPorts used for isolated backup net ports
Switchport mode private-vlan host
Switchport private-vlan host-association 550 551
and the promiscous port:
SW5020-02(config-if)# switchport mode private-vlan promiscuous
ERROR: Ethernet101/1/6: requested config change not allowed
#"¤&%#& - is this another limitations in the fex's ? As far as I can see from the reloease notes here
http://www.cisco.com/en/US/docs/switches/datacenter/nexus5000/sw/release/notes/Nexus_5000_Release_Notes.html
The Cisco Nexus 2000 Fabric Extender does not support PVLANs over VLAN trunks used to connect to another switch. The PVLAN trunks are only used on inter-switch links but the FEX ports are only meant to connect to servers. Since it is not a valid configuration to have an isolated secondary VLAN as part of a Fabric Extender port configured as a VLAN trunk, all frames on isolated secondary VLANs are pruned from going out to a FEX.
the "only" limitation should be the trunk option - but as far as I can see from the output from my nexus this is not correct - any suggestions?
We are running NXOS:
Software
  BIOS:      version 1.3.0
  loader:    version N/A
  kickstart: version 4.2(1)N2(1)
  system:    version 4.2(1)N2(1) Software
  BIOS:      version 1.3.0
  loader:    version N/A
Correct Answer by krahmani323 about 5 years 7 months ago
Hello tiwang,
At this time, promiscuous port is not supported on FEX Host interface =>
From the FEX configuration guide :
http://www.cisco.com/en/US/docs/switches/datacenter/nexus2000/sw/configuration/guide/rel_4_0_1a/FEX-features.html#wp1046108
VLANs and Private VLANs
The Fabric Extender supports Layer 2 VLAN trunks and IEEE 802.1Q VLAN encapsulation. Host interfaces can be members of private VLANs with the following restrictions:
• You can configure a host interface as an isolated or community access port only.
• You cannot configure a host interface as a promiscuous port.
• You cannot configure a host interface as a PVLAN trunk port.
Another document indirectly states it =>
http://www.cisco.com/en/US/prod/collateral/switches/ps9441/ps10110/data_sheet_c78-507093.html
Table 10. Feature Support for the Cisco Nexus 2000 Series
Layer 2 features :  Private VLANs (promiscuous only on uplinks)  [ie not supported on Hif].
FYI those intersting features (promiscuous port - promiscuous trunk – pvlan over Portchannel / VpC) are supported on the N5k interfaces.
From NX-OS 5.0(2)N1(1)
Private VLANs over Port Channel and vPC Interfaces
http://www.cisco.com/en/US/docs/switches/datacenter/nexus5000/sw/release/notes/Rel_5_0_2_N1_1/Nexus5000_Release_Notes_5_0_2_N2_1a.html#wp209253
From NX-OS 4.1(3)N1(1)
http://www.cisco.com/en/US/docs/switches/datacenter/nexus5000/sw/release/notes/Rel_4_1_3_N1_1/Nexus5000_Release_Notes_4_1_3_N1_1.html#wp185640
Hope that helps.
Kind regards.
Karim
Overall Rating: 5 (1 ratings)
Correct Answer
krahmani323 Sun, 01/01/2012 - 12:48
  • Silver, 250 points or more
Hello tiwang,
Hope that helps.
Kind regards.
Karim
Related Content
