12-31-2011 03:35 PM - edited 03-21-2019 05:08 AM
Okay, so I have Comcast cable for my internet, and I have AT&T for my phone server. I have 7 Analog phone lines. I have a UC320W phone system, and 5 SPA504G phones, and 1 Cisco POE 24 port Switch.
I am able to obtain an IP address for all my phones ( 10.1.10.x )
I am not, however, able to obtain a dial tone from any of the phones. I've plugged in 3 of the phone lines to the back of the UC320 to try and test some lines, and nothing works. I do have a dial tone if I plug in a regular phone.
I can access the configuration page to both the phones and the phone system without a problem.
What steps am I missing here?
12-31-2011 05:19 PM
You should get a dial tone on all phones even with no fxo or sip trunks. What model switch are you using? If its a sf200 or sf300 make sure the latest firmware is installed. The sf200 I used in my system arrived with outdated firmware. Once I updated to latest version with cdp everything was plug and play.
12-31-2011 07:49 PM
It's the SG200 and it has the latest firmware. All phones pick up a local IP address, I'm not sure how to direct the phones to certain Phone numbers. None of them are dialing or receiving phone calls.
12-31-2011 09:04 PM
After you configure the uc320w it will show you a dashboard overview of the system, are there any red or yellow boxes? Are you using the uc320w in PBX, Blend, or Key System mode? Do your spa504g display the assigned extension numbers?
I feel your pain and I'll do my best to help you out. I too am preparing to deploy a new system over this three day weekend.
12-31-2011 10:48 PM
I will be back on the office Monday. I'm using it in blend, I'll check for red/yellow boxes. Thanks for all your help ;-). I'll keep you posted.
01-02-2012 10:19 AM
Any news on the issue?
01-02-2012 04:39 PM
I was able to diagnose the issue. When I'm at the office tomorrow I'll give the explanation :-). Too much for iPhone.
01-02-2012 04:56 PM
Good to hear. Hope you enjoy the uc300 solution. I love mine so far.
