Easy VM-FEX Download
Answered Question
Dec 31st, 2011
Does anyone know if easy VM-FEX is available for download?
Correct Answer by Manish Tandon about 5 years 5 months ago
..and if by any chance the question was on the "easy" VM-FEX tool (which allows one to set up VM-FEX through a wizard), it will be posted on the developer network shortly as we plan to open source it.
The ETA (an educated guess as it depends on a few variables) is 2-3 weeks.
--Manish
Overall Rating: 5 (1 ratings)
abbharga Sat, 12/31/2011 - 22:30
  • Silver, 250 points or more
Hi Mike,
You can download it from the UCSM home page i.e. http(s)://
There is a link at the bottom.
A screen shot to help you:
./Abhinav
mwronkow Sun, 01/01/2012 - 17:12
  • Cisco Employee,
For UCS versions prior to 2.x, VIBs are included in Nexus 1000v software.  Use the latest patch of N1k available.  For example, if the table specifies SV1(4), use SV1(4a).
Correct Answer
Manish Tandon Tue, 01/03/2012 - 13:28
  • Bronze, 100 points or more
--Manish
colin.lynch Thu, 01/05/2012 - 07:51
From what I have seen of Easy VM-FEX on the advantage videos it looks a great tool. and look forward to having a play with it.
Until it is released, I have recorded all config required to setup VM-FEX (Emulated and VMDirectPath modes) and will add it to my blog site in the next day or so.
(Basically its just a recording of all the steps in a couple pdfs that Manish has directed me to previously).
Colin
sumit2907 Fri, 12/06/2013 - 21:37
Pls help me out in getting the tool. Or provide me any link to download (Easy VMFEX Tool).
