Softkey Template IP Phone 9971 SIP
Jan 2nd, 2012
  • " /> Participante em Destaque,
    Prêmio"Escolha dos membros": novembro de 2014
Hello Guys,
I am trying configure 02 IP Phones 9971 SIP in the CallManager 7.1.3. I Verified that for this version, there are not softkey template and an resource that I can use could be feature control policy. I enabled the feature control policy and apply in the ip phone but don´t appear in the ip phone the button with the for example: conference, call pickup, callback,...
Is there any step-by-step to configure this feature? or another way to configure this button template?
Wilson
Overall Rating: 5 (3 ratings)
Rob Huffman Mon, 01/02/2012 - 11:23
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Wilson,
Feature Buttons and Softkeys
Table 7-4 provides information about some of the features that are available on softkeys, some that are available on dedicated feature buttons, and some that you need to configure as programmable feature buttons. An "X" in the table indicates that the feature is supported for the corresponding button type or softkey. Of the two button types and softkeys, only programmable feature buttons require configuration in Cisco Unified IP Phone administration.
Note The Cisco Unified IP Phone 8961, 9951, and 9971 does not use softkey templates in Cisco Unified Communications Manager administration.
For information on configuring programmable feature buttons, see the "Modifying Phone Button Templates" section.
Table 7-4     Features and Corresponding Buttons and Softkeys
Feature Name
Dedicated Feature Button
Programmable Feature
Button
Softkey
All Calls
X
Answer
X
X
Call Back
X
X
Call Forward All
X
X
Call Park
X
X
Call Park Line Status
X
Call Pickup
X
Call Pickup Line Status
X
Conference
X
X
(available while on a conference only)
Divert
X
Do Not Disturb
X
Group Pickup
X
Hold
X
Hunt Groups
X
Intercom
X
Malicious Call Identification (MCID)
X
Meet Me
X
Mobile Connect
X
Mute
X
Other Pickup
X
Privacy
X
Redial
X
X
Speed Dial
X
X
Speed Dial Line Status
X
Transfer
X
X
(available during a transfer only)
Quality Reporting Tool (QRT)
X
Phone button templates let you assign speed dials and call-handling features to programmable buttons. Call-handling features that can be assigned to buttons include Answer, Mobility, and All Calls.
Ideally, you modify templates before registering phones on the network. In this way, you can access customized phone button template options from Cisco Unified Communications Manager during registration.
To modify a phone button template, choose Device > Device Settings > Phone Button Template in Cisco Unified Communications Manager Administration. To assign a phone button template to a phone, use the Phone Button Template field in the Cisco Unified Communications Manager Administration Phone Configuration page. Refer to Cisco Unified Communications Manager Administration Guide and Cisco Unified Communications Manager System Guide for more information.
The default Cisco Unified IP Phone 9971 template that ships with the phone uses buttons 1 and 2 for lines.
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/9971_9951_8961/7_1_3/english/admin/guide/9971usr.html#wp1077141
Cheers!
Rob
Please remember to tag your threads and help support "Teachers without Borders"
https://supportforums.cisco.com/community/netpro/idea-center/communityhelpingcommunity
wilsonsant Mon, 01/02/2012 - 11:34
Hi Rob,
I had already read the all documentation, but, didn´t solve the problem. I am not having possibility of add the button for example: conference, call park, call pickup, pickup group, etc.... I tried change the phone button template, but, too didn´t had sucess.
Wilson
cadjoe Sun, 04/26/2015 - 11:40
I had this same problem initially, but in CUCM 10, you can scroll all the way down on the device and change the
Softkey Control
TO:  Softkey Template.
Now it will get all the Softkey Buttons from the normal Softkey Template at the top.
CadJoe
CUCM, Gotta Love It!
wilsonsant Mon, 01/02/2012 - 11:36
Hi Rob,
I had already read the all documentation and apply the recommendation, but, this didn´t solve the problem. I am not having possibility of add the button for example: conference, call park, call pickup, pickup group, etc.... I tried change the phone button template, but, too didn´t had sucess.
Wilson
Chris Deren Mon, 01/02/2012 - 12:20
  • Hall of Fame,
    2017 IP Telephony, Contact Center, Unified Communications
Wilson,
9971 does not have conference softkey option, there is a conference hard button (one that has 3 heads), next to Transfer and Hold hard buttons.  Park, Conference List, Call Back, etc are available through feature control policy, they will only be available though under correct call state, i.e. you cannot use Park without an active call, etc.  Make sure you are trying to invoke these under correct phone states, if you still do not see them, make sure that the feature control policy has been assigned to your phone and has these Enabled (some are disabled by default) and try resetting the phone.
HTH,
Chris
wilsonsant Tue, 01/03/2012 - 02:38
Hi Chris,
I did the correct configuration and resetting the phone, but, didn´t work.
Wilson
Rob Huffman Tue, 01/03/2012 - 07:21
  • Hall of Fame,
    Founding Member
Hi Wilson,
When you go to Device> Device Settings> Phone Button Template > Find
9971SIP
You then Copy that default button template and rename it something else
like 9971SIP_feature
At this point you can add the features like Pickup & Park to buttons 3,4,5&6 via the
dropdown boxes then save.
Go back to the phones in question and change their Button Template to
9971SIP_feature and reset them. You should then see these keys/buttons
added when in the correct call state
Cheers!
Rob
wilsonsant Wed, 01/04/2012 - 05:11
Hi Rob,
This procedure was did, but, didn´t work. In this moment I have 04 IP Phones. 02 IP Phones show only 03 buttons: New call, forward all, redial and another 02 IP Phones shows new call, forward all, redial , more, re-call and self-view. If I obtain the first 02 phones the same configuration, for me is sufficente.
Wilson
wilsonsant Fri, 01/13/2012 - 10:42
Hi Rob,
I am sorry by long delay. I did the procedure, but, in this condittion the button is appearing in the vertical line I need that the button appear in the horizontal line. Do You understand?
Wilson
Rob Huffman Fri, 01/13/2012 - 11:00
  • Hall of Fame,
    Founding Member
Hi Wilson,
No worries my friend As you can see from the link below
the 9971 only has the vertical programmable feature buttons 18
so that's as good as it gets. Sorry man!
Figure 1-3     Cisco Unified IP Phone 9971
Table 1-3 describes the buttons on the Cisco Unified IP Phone 9971.
Table 1-3     Features on the Cisco Unified IP Phone 9971
Phone screen
Shows information about your phone, including directory number, call information (for example caller ID, icons for an active call or call on hold) and available softkeys.
Phone screen items, such as menu options and softkeys, are touch-sensitive.
Session buttons
Each represents a call session and takes the default action for that session. For example, pressing the session button for a ringing call answers the call, while pressing the session button for a held call resumes the call.
Color LEDs reflect the call state. LEDs can flash (blink on and off rapidly), pulse (alternately dim and brighten), or appear solid (glow without interruption).
Flashing amber—Ringing call
Solid green—Connected call or an outgoing call that is not yet connected
Pulsing green—Held call
Solid red—Shared line in-use remotely
Pulsing red—Shared line call put on hold remotely
(The position of session buttons may be reversed with that of programmable feature buttons on phones using a locale with a right-to-left reading orientation, such as Hebrew and Arabic.)
Back button
Returns to the previous screen or menu.
Release button
Ends a connected call or session.
Navigation pad and Select button
The four-way Navigation pad allows you to scroll through menus, highlight items, and move within a text input field.
The Select button (center of the Navigation pad) allows you to select a highlighted item, disable the phone screen for cleaning, or enable the phone screen if it is in power-save mode.
The Select button is lit (white) when the phone is in power-save mode.
6
Conference button
Creates a conference call.
7
Hold button
Places a connected call on hold.
8
Transfer button
Transfers a call.
9
Keypad
Allows you to dial phone numbers, enter letters, and choose menu items (by entering the item number).
Speakerphone button
Selects the speakerphone as the default audio path and initiates a new call, picks up an incoming call, or ends a call. During a call, the button is lit green.
The speakerphone audio path does not change until a new default audio path is selected (for example, by picking up the handset).
If external speakers are connected, the Speakerphone button selects them as the default audio path.
11
Mute button
Toggles the microphone on or off during a call. When the microphone is muted, the button is lit red.
12
Headset button
Selects the wired headset as the default audio path and initiates a new call, picks up an incoming call, or ends a call. During a call, the button is lit green.
A headset icon in the phone screen header line indicates the headset is the default audio path. This audio path does not change until a new default audio path is selected (for example, by picking up the handset).
13
Volume button
Controls the handset, headset, and speakerphone volume (off-hook) and the ringer volume (on-hook).
Silences the ringer on the phone if an incoming call is ringing.
14
Messages button
Auto-dials your voicemail system (varies by system).
15
Applications button
Opens the Applications menu. Depending on how your system administrator sets up the phone, use it to access applications such as call history, preferences, and phone information.
16
Contacts button
Opens the Contacts menu. Depending on how your system administrator sets up the phone, use it to access personal directory, corporate directory, or call history.
17
Phone display
Phone display that can be positioned to your preferred viewing angle.
18
Programmable feature buttons
Programmable feature buttons that correspond to phone lines, speed dials, and calling features.
Pressing a button for a phone line displays the active calls for that line. If you have multiple lines, you might have an All Calls feature button that displays a consolidated list of calls from all lines.
Color LEDs indicate the line state:
Amber—Ringing call on this line
Green—Active or held call on this line
Red—Shared line in-use remotely
(The position of programmable feature buttons may be reversed with that of session buttons on phones using a locale with a right-to-left reading orientation, such as Hebrew and Arabic.)
19
Handset with light strip
The handset light strip lights up to indicate a ringing call (flashing red) or a new voice message (steady red).
Cheers!
Rob
Gordon Ross Fri, 01/13/2012 - 11:16
  • Blue, 1500 points or more
89xx/99xx phones don't use the softkey template system. They use the "Feature Control Policy" system instead. (Device -> Device Settings -> Feature Control Policy) Nowhere near as flexible as softkey templates
GTG
wilsonsant Tue, 01/31/2012 - 04:11
Hi Gordon,
I am sorry by long delay. Is difficult give continue in the test. Well, I did alredy the configuration based in Feature Control Policy, but, didn´t work. I Would like configure new softkey for example: call park, call pickup, conference, but, in this moment only shows new calls, forward all, redial and recall
Thanks by patience,
Wilson
wilsonsant Wed, 02/22/2012 - 10:02
Hi Guys,
I am sorry by long delay. Today I started again the test about IP Phone 9971. I Configured the button in vertical line, but, didn´t work. For example, I configured the pickup but when I tryed the pickup the call didn´t work. Is not clear for me as function this phone model.
Wilson
