Automatic configuration upload on WLC?
Answered Question
Sep 7th, 2011
  • Silver, 250 points or more
Is there a way to schedule automatic configuration uploads (backups) on WLCs? It should be done without using WCS.
Thank you in advance.
Andras
The solution has been added in the following document;-
https://supportforums.cisco.com/docs/DOC-21757
Correct Answer by ericgarnel about 5 years 8 months ago
There is a way to do this using expect scripts
See my post at https://supportforums.cisco.com/message/3438495#3438495
you can use cron to call the shell script that calls the commands expect file.
commands expect script for backing up configs. Change the script upload variables for your environment
#!/usr/bin/expect
set router [ lindex $argv 0]
set username [ lindex $argv 1]
set password [ lindex $argv 2]
spawn ssh $router
#log_user 0
set timeout 10
expect "(yes/no)?" {
send "yes\r"; exp_continue }
expect "User:"
send -- "$username\r"
expect "assword:"
send -- "$password\r"
expect "Controller"
send -- "transfer upload datatype config\r"
expect "Controller"
send -- "transfer upload mode tftp\r"
expect "Controller"
send -- "transfer upload serverip \r"
expect "Controller"
send -- "transfer upload start\r"
# some wlc config commands require yes/no verification
expect "(y/N)"
send -- "y\r"
expect "Controller"
send "logout\r"
expect "(y/N)"
send -- "n\r"
expect eof
Overall Rating: 5 (2 ratings)
Surendra BG Wed, 09/07/2011 - 05:50
  • Cisco Employee,
hmmmm... i am not aware of such stuff without using WCS... u can go for SNMP WALK using any freeware SNMP stuffs from the net..
Surendra
sachinc01 Thu, 02/25/2016 - 21:31
Hi Sir,
How to take back up of
Model: AIR-CT2504-25-K9Z Ask file path & file name Which name I will asign for back up..
Any one name or perticuller please suggest
Correct Answer
ericgarnel Wed, 09/07/2011 - 13:03
  • Gold, 750 points or more
#!/usr/bin/expect
spawn ssh $router
#log_user 0
set timeout 10
expect "User:"
expect "assword:"
expect "Controller"
expect "Controller"
expect "Controller"
expect "Controller"
expect "(y/N)"
send -- "y\r"
expect "Controller"
send "logout\r"
expect "(y/N)"
send -- "n\r"
expect eof
Related Content
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
