Warning message
4500-E, SUP II Plus TS, force a Enterprise Services IOS
Answered Question
Jan 3rd, 2012
I know that this is no correct,
I know that it will not be supported,
I know that a thing like that shoudl not go to a productiona enviroment.
BUT, doe anyone kows what wolud happend if a force a cat4500-entservicesk9-mz.122-54.SG on a SUP-II-Plus+TS?
Considering that:
- The same IP base file tha is used on a SUP-II-Plus+TS is used uma a SUP-V
- The file size os the entservices IOS is just a bit bigger the ipbase IOS.
- Especificaly the EIGRP were supported on the SUP-II-Plus+TS pior the 12.2-25
We need full support to EIGRP(or OSPF) because of the H.A that are been implemented,.and need to test it...
Correct Answer by Leo Laohoo about 5 years 7 months ago
Douglas Fernando Fischer wrote:
When you say "card won't accept this IOS" it means:
  • On copy tftp bootflash: the system will recuse the file !?!
    • I have on seen some like that using xtract command, not copy command.
  • On the reload, the system goes to ROMMON !?!
You can copy the IOS into your Sup2 and you can change the boot string to point to this IOS without any issues, HOWEVER, once you reboot your chassis the supervisor card will look at the boot string and ATTEMPT to run the IOS.  It will go something like, "I can do this, I can do this, I can ... hold on.  WTF is this instruction(s)?  I don't understand this.   Abort".  If you have another valid IOS in there, the supervisor card will try to boot that too.  If you don't then the supervisor card will go into ROMmon.
Overall Rating: 5 (1 ratings)
Leo Laohoo Tue, 01/03/2012 - 18:47
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
The supervisor card won't accept this IOS because the CPU can't understand some of the instructions in the code.
Douglas Fernand... Wed, 01/04/2012 - 03:15
Correct Answer
Leo Laohoo Wed, 01/04/2012 - 13:19
  • Hall of Fame,
    2017 LAN, Wireless
Douglas Fernand... Wed, 01/04/2012 - 17:19
Humm...
Make sense, in part.
I Think It worth the try.
Now I will try to find and image with less then 7 megs, and leave both on bootflash:
If possible, I will capture the output of the boot and post here.
Leo Laohoo Wed, 01/04/2012 - 18:58
  • Hall of Fame,
    2017 LAN, Wireless
Your Supervisor card will only read IP Base.  If it reads anything else, it'll go pffffft.
