01-04-2012 11:12 AM - edited 03-21-2019 05:08 AM
We have a strange issue with our UC320.
All the inbound calls are going to a shared extension which has two phones in it. On busy/no answer it goes to an Auto Attendant. Time to time it goes straight to Auto attendant without even trying to go to Shared Extension. We have checked everything we could the DnD is not enabled, phones are up and running, I can call phone’s extension without any problems. Every time it happens we have to reboot UC320 and then it works normally. There are 5 analog lines in.
Any thoughts?
Thanks!
01-05-2012 07:22 AM
Do you use different settings for day/night call routing?
01-05-2012 08:11 AM
Yes, there is a night AA with a manual switch.
01-05-2012 09:43 AM
Make sure you are on the latest Limited Deployment release.
https://supportforums.cisco.com/message/3516701#3516701
Suggest the next time that this happens that you log into the configuration utility, enable logs on your FXO ports. Make the inbound call on FXO, then look at/capture the logs before power cycling the system. Suggest opening a case with the Cisco Small Business Support center:
http://www.cisco.com/en/US/support/tsd_cisco_small_business_support_center_contacts.html
Chris
