Warning message
Upgraded from CM 7.1.5 to 8.6.2 - Startup Warning
Jan 4th, 2012
This is in relation to another discussion I started for the upgrade itself, but since the upgrade is done and this is a different issue, figured I'd start a new discussion.
As the title implies, I just finished an upgrade from 7.1.5 to 8.6.2. My data is all there and working fine in 8.6.2, however each time I reboot the VM's I get the two attached warnings before the VM's will start up.  Anyone seen these before?  How do I get rid of them?
I was thinking about doing a DR backup of my 8.6.2, recreating two new 8.6.2 vm's and restoring to those.  I was thinking maybe something didn't quite go right in my 7.1.5 to 8.6.2 upgrade. ??
Jaime Valencia Wed, 01/04/2012 - 14:12
  • Cisco Employee,
  • Hall of Fame,
    2011
You need to start by mentioning the details of the upgrade and HW being used.
Was 7.1(5) on VM?? if so, that's not a supported path for upgrading to VM supported version and most likely the cause of the error.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
acampbell Wed, 01/04/2012 - 15:31
  • Green, 3000 points or more
As you are upgrading to 8.6.
I think you need to dowload and run
ciscocm.refresh_upgrade_v1.1.cop.sgn
This is an OS patch that is required before the CUCM upgrade can be run.
Please see the read me file on the dowload page
Alex
snooter Mon, 01/09/2012 - 06:23
I ended up having to built up new machines and just used the Import/Export option under bulk admin from the old servers to the new.  Problem solved.
