01-04-2012 07:17 PM - edited 03-07-2019 04:11 AM
Does anybody know if VPC is supported with WLC 5508?
I am running 5.1.(3).
01-04-2012 08:30 PM
WLC doesn't support vPC. You can configure regular LACP PO which uplink to both Nexus (N7K's PO will be configured as vPC).
jerry
01-04-2012 08:36 PM
would mode "on" also work on the PO from the Nexus to the WLC?
01-04-2012 08:40 PM
Recommended setting is LACP. On will work if LACP is not an option, but misconfigured PO can cause traffic blackhole.
HTH,
jerry
04-27-2012 08:51 AM
I'm very confused by jeye comments.
I know for a fact that WLC 5508 does not support " channel-group 1 mode active"
Bottom line, can you connect a WLC 5508 to a pair of Nexus 7000 using vPC ?
If yes, can I use the following command to setup vPC on each Nexus ?
interface Ethernet1/1
switchport
switchport mode trunk
switchport trunk native vlan 100
channel-group 1 mode on
no shutdown
interface port-channel1
switchport
vpc 1
Thank you
04-27-2012 09:09 AM
That is fine on the Nexus side.
What I am saying is, WLC will not have the "vpc" command option. All you can do is regular port-channel.
HTH,
jerry
02-15-2013 05:07 AM
hi,
its absolutely possibe.
1. ensure you enabled LAG on WLC
2. Assign 0 as vlan id on management interface (untagged), assuming u only hav management interaface.
if u have other AP manager interface then configure vlan id as 0 for those int also.
3.in both nexus,configure portchannel with vPC, assign it on physical interface(same as wht u hav mentioned above)
it should work if you follow the above procedure.
because i am having 2 no of 5508 and 2 no of nexus 7010, the above setup works fine.
Arun
+919900097880
03-02-2014 08:01 AM
But how do you enable port-channeling on the actual 5508?
Does it automatically bundle all uplink ports?
I know with the 7ks all configs have to match or else it won't bring up the port-channel.
03-02-2014 10:09 AM
Adam
I haven't worked with the WLC 5508 but from the configuration guide you need to enable LAG and reboot the device -
Jon
03-03-2014 05:07 AM
Yeah I understand how to do that part and have it enabled already. I just thought there would be more to it on the 5508 since its an appliance. Even though its not a switch IOS persay I was thinking it would still port-channel the same as a switch.
