UCCX Script: Using "Set Contact Info" for disconnected caller (caller hung up)
Jan 5th, 2012
I seem to have some problem using the Set Contact Info function.
Attached is a screen shot of my script.
When caller hangs up, the call will flow to the Exception (ContactInactiveException) Goto LABEL0.
And the on the LABEL0, it will clear the Exception. And if the call_handled variable is set to 1. It will flow to the Set Contact Info whereby i set the call to handled.
When doing the reactive script debug all seems to go well on the proper flow.
When then on the CSD i still see the call as abandon and not as handled.
Any suggest what could be the issue.
Subash
Steven Pawlak Thu, 01/05/2012 - 13:28
Cause your False branch sets call_handled to zero not one.
That script has some bad logic flow and needs to be looked at more closely. I suggest you look at Vol1 of the Scripting guides to see how to properly queue and loop a call.
subash cobi Thu, 01/05/2012 - 21:04
hi Steven,
Ya, the false branch does set the call_handled to zero, that what i want.
Only the call goes thru the true branch it will set the call_handled to one.
And the on Exception (ContactInactiveException) it goes to a IF statement that set the call staed to handle if the call_handled is 1.
The call flow works as desired. Only it is not setting the call as handled instead it is a call abandon under the CSQ data.
subash cobi Fri, 01/06/2012 - 00:35
Just tested it seem that the function "Set Contact Info" used to set the call to handle only reflects on the the Histrocial reporting.
And does not reflect on the Real-Time Reporting from UCCX or Cisco Supevisor Desktop.
On the Real-Time Reporting from UCCX or Cisco Supevisor Desktop, it still shows as call abandoned.
Any idea how to make to reflect on the Real-Time Reporting from UCCX and Cisco Supevisor Desktop.
Cause the client has a Wallboard and want it to reflect on it, and the wallboard grabs the data from the Real-Time Reporting from UCCX.
Gergely Szabo Sun, 01/08/2012 - 23:00
Hi, can you give us more information on what you would like to achieve from the other way around: for instance, you would like to present X on the wallboard etc.
G.Sz.
Login or Register to take actions
Posted January 5, 2012 at 12:48 AM
Stats:
Replies:4 Overall Rating:
Views:1445 Votes:0
Shares:0
Tags: No tags.
Discussions Leaderboard
Rank Username Points
Anthony Holloway
3,643
Jonathan Schulenberg
3,119
Aaron Harrison
2,922
geoff@hp.com
2,673
Gergely Szabo
2,596
Aaron Harrison
89
djlundberg
64
Gergely Szabo
52
Marcelo Almeida...
46
chintan gajjar
34
