How to integrate UC540 with existing customers network?
Jan 5th, 2012
My customer has just purchased 16 SPA525G2 IP Phones as well as a UC540W-FXO-K9 from me and I am having a heck of a time getting it to work correctly.
The infrastructure currently looks like this; WAN>Sonicwall NSA240>LAN (192.168.1.1/24) which consists of Two 200 Series Smart Switches and One HP/3Com layer 3 managed switch. The switches are all just plugged in and are all default so nothing is configured.
I need to figure out where I can position the UC540W in the network. I'm not very familiar with VLANs but I did work with them in High school about 6-7 years ago. Therefore I do not remeber much when it comes to this aspect...
If I simply configure the UC540W with CCA in this way; WAN>UC540>LAN VLAN1 for Data and VLAN100 for Voice as default in setup of the UC540 It works fine as far as the phone registering etc. but if I plug in the 200 Series Smart Switch to the Expanision port on the UC540 and plug phones into that switch they will not register and act as if they are not able to reach the UC540. I also tried plugging this switch into one of the 8 other LAN ports on the UC540 to see if that would work and I didn't have any luck...
I have spent over 40-50 Hours trying to figure this out on my own... I really need some direction on what to do here. I did look up how to integrate the UC500 Series with a thirdparty firewall and found some documents put out by cisco but it was no help. I am confused on how I can get the UC540 to just plug into the network lan that is there and then have the phones register through dhcp with the sonicwall NSA240. It does have some VOIP features with options under the DHCP scopes for Call Manager 1/2/3.
Could someone help get me pointed in the right direction please? Also I'm a Cisco Selct Certified Partner and was wondering if I have a Cisco tech I could call to guide me through this possibly? The customer did purchase the 3 year smartnet warranty service by the way if that helps. Thank You
David Trad Thu, 01/05/2012 - 18:24
  • Gold, 750 points or more
  • Cisco Designated VIP,
    2013 Small Business
Hi Gregory,
I am going to assume a couple of things here, firstly that the 200 series switches you refer to are Cisco switches and that you have a network topology already drawn up?
With the UC's there are only 3 ways of doing this:
  • Fully integrated and it controls the network
  • Semi integrated and it works with the existing domain controller I.E SBS server et'all
  • Not integrated at all and operates indapendantly to the existing network
In your case you only have two options unless you wanted to radically re-design the network and its current topology, and the most likely one for you to choose is option (2) which is semi integrated.
In this instance you will want to have a full and proper network topology, and your UC will be just another statically assigned appliance in the network, with one caveat, it will do some form of routing in particular the inter-vlan-routing so the data subnet can talk to the voice subnet... But in saying that which ever device is the network controller, it will need to have a route to all the VLAN's the UC has as the UC is not the network controller.
So in your instance and without knowing much about your network topology and no diagram to work of, I would assume the following topology:
  • Edge routing device (ADSL modem?) 192.168.1.254
  • Sonic Firewall 192.168.1.253
  • Cisco UC-500 192.168.1.252
  • Cisco Switch-1 192.168.1.251
  • Cisco Switch-2 192.168.1.250
  • HP Switch 192.168.1.249
UC-540 has 8 inbuilt PoE 10/100 FE ports, of which one of them would could be an ideal candidate to be connected directly into the network to make the UC LAN side ( In the olden days the CLI jockey's would turn the WAN port into a LAN port, but CCA wont let you), or alternatively you can use a Gig-E trunk port on a switch to do this.
At least one of your Cisco switches would need to be connected to the expansion port of the UC and the secondary one connected to a trunk port, this way SmartPort roles can be correct applied across all appliances by CCA so that all VLAN's are also correctly applied.
All Switches and Routers would need to operate within your Data VLAN and phones within the voice VLAN, I would highly encourage you to keep them as default, in particular the Voice VLAN, I.E keep the subnet and the VLAN ID as default, only change them when it is an absolute must.
During the Telephony setup Wizard you configure the system up as normal, preferably untethered from the rest of the network in a staged environment, you also configure the network settings up as if the UC was controlling the network, then once it is all over and the TWS has done its job, you would use CCA to disable the DHCP service on VLAN 1, this way the UC just sits statically within the network.
If you are not using Cisco Switches with the UC, you are mad and really need to reconsider what you are doing, I don't think I need to state the obvious and the reasons why, but in the future also make sure you only use the Cisco SF/SG-300 series switch, these are fit for the purpose and in my opinion (Yes my opinion that wont be shared with others) are the ideal ones for a UC deployment unless it is a UC-320 which the 200 series is fine for.
You will also need to trunk the HP switch to the Switch that is directly connected to the UC, and make sure that in CCA you configure that particular port on that Cisco switch as a Switch Port, this way all the VLAN's are set correctly on that port, the rest is then up to the HP switch, if it is not VLAN aware or VLAN capable then you need to tell the client to upgrade to a better switch
Now where possible keep the Sonic wall away from the UC they do not play very nice together and despite it saying it supports voice features, I personaly myself would not use it as a boat anchor for my boat use it as a firewall device and do not let it touch anything to do with the UC, the UC itself would be a better firewall system then the Sonic, but if you must keep it then do so, just do not let it try and control anything to do with the UC what-so-ever the UC is its own controller and its own master, it will integrated to an already controlled network, but it will not like you or the network one bit if another device tries to tell it what to do, and that is the most clearest and simpliest way I can put that across to you
Also note that the UC should issue out the DHCP for the voice VLAN, whilst I know of quite a few sites that have the SBS server or other forms of domain/network controllers doing it and it works, they do have constant issues and too much time is spent managing that network, let the UC do what it does best and let it manage the DHCP for the phone, just make sure the phones are connected to a switch that is directly connected to the UC or the phones connected directly into the UC.
Errr that is all I can think of right now to get your started, if you need more info or clarification on anything just let us know, but in all cases if you have a support contract on the system, do get support involved they can make sure the system is integrated according to the Cisco Smart Design, which is ideal for you to do so
Cheers,
David.
gschafferjr Fri, 01/06/2012 - 02:37
So I did everything you said to do David. 1. Ran TSW and kept everything default and only setup one user/phone/ext
2. Connected SG200-50 Port Switch to Expansion port on UC540 and added to community in CCA.
3. Deleted DHCP Scope for VLAN1
4. Changed ip of CiscoSwitch 1 and 2 to 192.168.1.250/192.168.1.251
5. Connected 3Com L3 Managed Switch to Port on Switch 2 after changing the ports for the Cisco Switch to Smartports Mode "Switch" in CCA
6. Tried to Change IP of UC540W VLAN1 from 192.168.10.1 to 192.168.1.252 but that did not work.... It just froze up CCA and I had to terminate the app. Device IP address remained 192.168.10.1
7. Had to modify the site in CCA so the two cisco switches and the uc540 would show up again after the app crashed.
8. So I could do step number 7 I went into tcp/ip properties and manually added one ip address in the 192.168.1.1/24 subnet and one in the 192.168.10.1 /24 subnet by clicking adavnaced and then add under ip addresses.
Also I planned on connecting the pc's to the pc port on the phones so I need the pc's to keep their connectivity with the static ip's set already which is in the 192.168.1.1/24 subnet. IS this a problem? And also I ran into a problem with the 10.1.1.1/24 subnet as one of the offices in california is on this via site to site vpn through the sonicwall...
One last question I think... I hope at least. If I removed the dhcp scope for Vlan 1 on the uc540 then how do the phones know where to get their config from when they boot up? I've looked at all the options in dhcp for the sonicwall and I am just really overwhelmed. I used to teach CCNA but it has been so long that its just about dissapeared from my memory it seems like. I stayed up for the past two days trying to get this system to work. So far a total of 87 hours has gone into learning this over again...
I hate sonicwall products... I love Cisco products but it has just been a while to say the least since I have done anything with them beside sticking some smart switches in for my customer who ordered them a while back.
Thanks for all the help! It is appreciated GREATLY
Message was edited by: Gregory Schaffer, Jr. I also forgot to mention I took snippets of a bunch of things I did which I will add after I wake up from a couple hours of sleep... Thanks Again
David Trad Mon, 02/13/2012 - 15:38
    2013 Small Business
Hi Gregory Schaffer, Jr.
Mate you will have to forgive me, I never got a notification on your reply and have totally missed this I am really sorry and a little disappointed.
Can you please advise on update on this?
Hi Akwu Sani
Please make sure that the connection from the smoothwall into the switch is connected into the trunk port of the switch, this way all VLAN's pass through, and make sure that the post is setup as "Router" smartport or if that does not work as expected than "Access" smartport role.
Secondly if you are going to have the UC-540 LAN side and also WAN side of the Smoothwall, then you need you need to isolate a port on the smoothwall, give it a Subnet that is way different to all the others on the network, and then statically assign an IP address to the UC-540 WAN port in that subnet with the Smoothwall being the default gateway.
Using CCA you can remove the DHCP scope on the data VLAN, then when the devices on the network request option 150 the Smoothwall should respond, however though if your LAN side connectivity to the Smoothwall is not right well nothing will pass through to it correctly.
If you are still using the UC to route traffic on the network until it hits the Smooth wall, then please draw a network diagram for us so we can all see what you are trying to achieve, as pictures can speak a thousand words.
Look forward to hearing back from both of you
Cheers,
David.
Akwu Sani Tue, 02/14/2012 - 08:49
Thanks David, attached herewith is the topology diagram of our existing network and our proposed network. Hope this helps.
from the proposed network diagram:
     1. The smoothwall is configured with the ISP's details on its RED interface
     2. The smoothwall's GREEN interface (LAN) is configured with 192.168.100.1 static IP
     3. The smoothwall is configured also to give dhcp 192.168.100.0/28
     4. The smoothwall GREEN interface is connected to the UC's WAN interface and the WAN interface gets IP via dhcp from the smoothwall.
     5. The expansion port on the UC is connected to the trunk port of the cisco sg-200 smart poe switch.
     6. Dhcp pool data on the UC is deleted
     7. Users behind the cisco switch are expected to get the 192.168.100.x IP from the smoothwall but they aren't.
     8. Phones Connected to the cisco switch are equally expected to work but they arn't, just downloading forever.
     9. PCs connected wirelessly to the UC are expected to get the 192.168.100.x ip from the smoothwall but they aren't.
Hope my explanation helps. Thanks
David Trad Tue, 02/14/2012 - 19:57
    2013 Small Business
Hi Akwu,
The diagram is great, it gives me an insight into what you are trying to achieve...
If you know how to use the CLI it would be good if you could give us a "sh run" (No quotes) so see how the system is configured now, this will help me to work out what you need to change using CCA (To stay compliant).
If you cannot do it, let me know what time zone you are in and we may need to organize a remote session so I can at least get a hands on view of the problem.
(PS) The original topology was ok you would have just needed to change 2 settings to get it to work, the new one does require a bit of reconfiguration in order for it to work right
Cheers,
David.
Akwu Sani Wed, 02/15/2012 - 05:10
Thanks David, below is the running config and my time zone is GMT +1
Building configuration...
Current configuration : 36439 bytes
! Last configuration change at 04:57:12 PST Wed Feb 15 2012 by cisco
! NVRAM config last updated at 01:03:11 PST Tue Feb 14 2012 by cisco
version 12.4
parser config cache interface
no service pad
service internal
service compress-config
service sequence-numbers
hostname UC540
boot-start-marker
boot-end-marker
security passwords min-length 1
enable secret 5 $1$a9iN$qJVFoo1ZqbsdTQdcx88DF.
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
clock timezone PST -8
clock summer-time PST recurring
crypto pki trustpoint TP-self-signed-3729251524
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3729251524
revocation-check none
rsakeypair TP-self-signed-3729251524
crypto pki certificate chain TP-self-signed-3729251524
certificate self-signed 01
  3082023D 308201A6 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 33373239 32353135 3234301E 170D3132 30323134 30373239
  34365A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 37323932
  35313532 3430819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100A1DF 59BF4EBE 3C2E97BD 719445B1 AEBF5A89 52C9D42E 6525D415 96156B90
  B5C7237D B009279B A6D7E598 2B91B9BD 43DF061D 4F84321D 06C64CF9 E8A94EB0
  39778268 329F0B2D AF35788B 3F8869FC 890C9B36 4202E5A7 32454CFA B1196269
  15B783C6 AFAE48AD 517ED448 84CA722C D14F68B0 3C74DE4A FE0EA305 30323DCB
  DA850203 010001A3 65306330 0F060355 1D130101 FF040530 030101FF 30100603
  551D1104 09300782 05554335 3430301F 0603551D 23041830 16801447 0216925F
  BA6A1FFF 3D955912 A0E31064 F37D8B30 1D060355 1D0E0416 04144702 16925FBA
  6A1FFF3D 955912A0 E31064F3 7D8B300D 06092A86 4886F70D 01010405 00038181
  008994C3 CE8FFB6B 18BAFA01 A06EA15B 5F07BA7F C76FA1A7 D3C99711 68685921
  701E5BC1 54417169 E72F6216 68496FC4 8240B37D 9F79F9F5 CD4C92EA D79A3007
  AEB77A8C BE8156B8 A16259A9 CC580DB5 A4896884 F0DEF416 7839542B 0958416B
  2285FD31 69FDA9A7 50C15B89 D4896A84 48567532 8EF05718 D1AECC72 C3C88F46 65
  quit
dot11 syslog
dot11 ssid Bwave
vlan 1
authentication open
authentication key-management wpa
guest-mode
wpa-psk ascii 0 1234509876
dot11 ssid cisco-voice
vlan 100
authentication open
ip source-route
ip cef
ip dhcp relay information trust-all
ip dhcp excluded-address 10.1.1.1 10.1.1.10
ip dhcp excluded-address 192.168.10.1 192.168.10.10
ip dhcp pool phone
   network 10.1.1.0 255.255.255.0
   default-router 10.1.1.1
   option 150 ip 10.1.1.1
ip dhcp pool data
   import all
   network 192.168.10.0 255.255.255.0
   default-router 192.168.10.1
ip inspect name SDM_LOW cuseeme
ip inspect name SDM_LOW dns
ip inspect name SDM_LOW ftp
ip inspect name SDM_LOW h323
ip inspect name SDM_LOW https
ip inspect name SDM_LOW icmp
ip inspect name SDM_LOW imap
ip inspect name SDM_LOW pop3
ip inspect name SDM_LOW netshow
ip inspect name SDM_LOW rcmd
ip inspect name SDM_LOW realaudio
ip inspect name SDM_LOW rtsp
ip inspect name SDM_LOW esmtp
ip inspect name SDM_LOW sqlnet
ip inspect name SDM_LOW streamworks
ip inspect name SDM_LOW tftp
ip inspect name SDM_LOW tcp
ip inspect name SDM_LOW udp router-traffic
ip inspect name SDM_LOW vdolive
no ipv6 cef
stcapp ccm-group 1
stcapp
trunk group ALL_FXO
max-retry 5
voice-class cause-code 1
hunt-scheme longest-idle
voice call send-alert
voice rtp send-recv
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
sip
  no update-callerid
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice class cause-code 1
no-circuit
voice translation-rule 1000
rule 1 /.*/ //
voice translation-rule 1112
rule 1 /^9/ //
voice translation-rule 2001
voice translation-rule 2222
rule 1 /^91900......./ //
rule 2 /^91976......./ //
voice translation-profile CALLER_ID_TRANSLATION_PROFILE
translate calling 1111
voice translation-profile CallBlocking
translate called 2222
voice translation-profile OUTGOING_TRANSLATION_PROFILE
translate called 1112
voice translation-profile nondialable
translate called 1000
voice-card 0
license udi pid UC540W-FXO-K9 sn FGL153326EC
username cisco privilege 15 secret 5 $1$yHgB$XZ3ibfEQd9kxrQKS9/R6r.
archive
log config
  logging enable
  logging size 600
  hidekeys
ip tftp source-interface Loopback0
class-map match-all _class_Voice0
match ip dscp ef
class-map match-all _class_Voice1
match ip dscp cs3
policy-map Voice
class _class_Voice0
  set cos 6
class _class_Voice1
  set cos 3
bridge irb
interface Loopback0
description $FW_INSIDE$
ip address 10.1.10.2 255.255.255.252
ip access-group 101 in
ip nat inside
ip virtual-reassembly
interface FastEthernet0/0
description $FW_OUTSIDE$
ip address dhcp
ip access-group 104 in
ip nat outside
ip inspect SDM_LOW out
duplex auto
speed auto
interface Integrated-Service-Engine0/0
description cue is initialized with default IMAP group
ip unnumbered Loopback0
ip nat inside
service-module ip address 10.1.10.1 255.255.255.252
service-module ip default-gateway 10.1.10.2
interface FastEthernet0/1/0
switchport voice vlan 100
macro description cisco-phone
spanning-tree portfast
interface FastEthernet0/1/1
interface FastEthernet0/1/2
interface FastEthernet0/1/3
interface FastEthernet0/1/4
interface FastEthernet0/1/5
interface FastEthernet0/1/6
interface FastEthernet0/1/7
interface FastEthernet0/1/8
switchport mode trunk
macro description cisco-switch
interface Dot11Radio0/5/0
no ip address
encryption vlan 1 mode ciphers aes-ccm
ssid Bwave
ssid cisco-voice
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
channel 2412
station-role root
service-policy output Voice
interface Dot11Radio0/5/0.1
encapsulation dot1Q 1 native
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio0/5/0.100
encapsulation dot1Q 100
bridge-group 100
bridge-group 100 subscriber-loop-control
bridge-group 100 spanning-disabled
bridge-group 100 block-unknown-source
no bridge-group 100 source-learning
no bridge-group 100 unicast-flooding
interface Vlan1
no ip address
bridge-group 1
interface Vlan100
no ip address
bridge-group 100
interface BVI1
ip address 192.168.10.1 255.255.255.0
ip access-group 102 in
ip nat inside
interface BVI100
ip address 10.1.1.1 255.255.255.0
ip access-group 103 in
ip nat inside
ip forward-protocol nd
ip route 10.1.10.1 255.255.255.255 Integrated-Service-Engine0/0
ip http server
ip http authentication local
ip http secure-server
ip http path flash:/gui
ip dns server
ip nat inside source list 1 interface FastEthernet0/0 overload
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 10.1.1.0 0.0.0.255
access-list 1 permit 192.168.10.0 0.0.0.255
access-list 1 permit 10.1.10.0 0.0.0.3
access-list 100 remark auto generated by SDM firewall configuration
access-list 100 remark SDM_ACL Category=1
access-list 100 deny   ip 192.168.10.0 0.0.0.255 any
access-list 100 deny   ip host 255.255.255.255 any
access-list 100 deny   ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip any any
access-list 101 remark auto generated by SDM firewall configuration
access-list 101 remark SDM_ACL Category=1
access-list 101 permit tcp 10.1.1.0 0.0.0.255 eq 2000 any
access-list 101 permit udp 10.1.1.0 0.0.0.255 eq 2000 any
access-list 101 deny   ip 192.168.10.0 0.0.0.255 any
access-list 101 deny   ip 10.1.1.0 0.0.0.255 any
access-list 101 deny   ip host 255.255.255.255 any
access-list 101 deny   ip 127.0.0.0 0.255.255.255 any
access-list 101 permit ip any any
access-list 102 remark auto generated by SDM firewall configuration
access-list 102 remark SDM_ACL Category=1
access-list 102 deny   ip 10.1.10.0 0.0.0.3 any
access-list 102 deny   ip 10.1.1.0 0.0.0.255 any
access-list 102 deny   ip host 255.255.255.255 any
access-list 102 deny   ip 127.0.0.0 0.255.255.255 any
access-list 102 permit ip any any
access-list 103 remark auto generated by SDM firewall configuration
access-list 103 remark SDM_ACL Category=1
access-list 103 permit tcp 10.1.10.0 0.0.0.3 any eq 2000
access-list 103 permit udp 10.1.10.0 0.0.0.3 any eq 2000
access-list 103 permit udp any 10.1.10.0 0.0.0.3 range 16384 32767
access-list 103 permit udp 10.1.10.0 0.0.0.3 range 16384 32767 any
access-list 103 deny   ip 192.168.10.0 0.0.0.255 any
access-list 103 deny   ip host 255.255.255.255 any
access-list 103 deny   ip 127.0.0.0 0.255.255.255 any
access-list 103 permit ip any any
access-list 104 remark auto generated by SDM firewall configuration
access-list 104 remark SDM_ACL Category=1
access-list 104 deny   ip 10.1.10.0 0.0.0.3 any
access-list 104 deny   ip 192.168.10.0 0.0.0.255 any
access-list 104 deny   ip 10.1.1.0 0.0.0.255 any
access-list 104 permit udp any eq bootps any eq bootpc
access-list 104 permit icmp any any echo-reply
access-list 104 permit icmp any any time-exceeded
access-list 104 permit icmp any any unreachable
access-list 104 deny   ip 10.0.0.0 0.255.255.255 any
access-list 104 deny   ip 172.16.0.0 0.15.255.255 any
access-list 104 deny   ip 192.168.0.0 0.0.255.255 any
access-list 104 deny   ip 127.0.0.0 0.255.255.255 any
access-list 104 deny   ip host 255.255.255.255 any
access-list 104 deny   ip any any
tftp-server flash:/phones/7940_7960/P00308001000.bin alias P00308001000.bin
tftp-server flash:/phones/7940_7960/P00308001000.loads alias P00308001000.loads
tftp-server flash:/phones/7940_7960/P00308001000.sb2 alias P00308001000.sb2
tftp-server flash:/phones/7940_7960/P00308001000.sbn alias P00308001000.sbn
tftp-server flash:/phones/7914/S00105000300.sbn alias S00105000300.sbn
tftp-server flash:/phones/7915/B015-1-0-3.SBN alias B015-1-0-3.SBN
tftp-server flash:/phones/7916/B016-1-0-3.SBN alias B016-1-0-3.SBN
tftp-server flash:/phones/7936/cmterm_7936.3-3-16-0.bin alias cmterm_7936.3-3-16-0.bin
tftp-server flash:/phones/7937/apps37sccp.1-3-2-0.bin alias apps37sccp.1-3-2-0.bin
tftp-server flash:/phones/521_524/cp524g-8-1-17.bin alias cp524g-8-1-17.bin
tftp-server flash:/phones/525/spa525g-7-1-9.bin alias spa525g-7-1-9.bin
tftp-server flash:/phones/5x5/spa5x5-7-1-3c.bin alias spa5x5-7-1-3c.bin
tftp-server flash:/phones/7921/APPS-1.2.1.SBN alias APPS-1.2.1.SBN
tftp-server flash:/phones/7921/CP7921G-1.2.1.LOADS alias CP7921G-1.2.1.LOADS
tftp-server flash:/phones/7921/GUI-1.2.1.SBN alias GUI-1.2.1.SBN
tftp-server flash:/phones/7921/SYS-1.2.1.SBN alias SYS-1.2.1.SBN
tftp-server flash:/phones/7921/TNUX-1.2.1.SBN alias TNUX-1.2.1.SBN
tftp-server flash:/phones/7921/TNUXR-1.2.1.SBN alias TNUXR-1.2.1.SBN
tftp-server flash:/phones/7921/WLAN-1.2.1.SBN alias WLAN-1.2.1.SBN
tftp-server flash:/phones/7925/APPSH-1.3.1.SBN alias APPSH-1.3.1.SBN
tftp-server flash:/phones/7925/CP7925G-1.3.1.LOADS alias CP7925G-1.3.1.LOADS
tftp-server flash:/phones/7925/GUIH-1.3.1.SBN alias GUIH-1.3.1.SBN
tftp-server flash:/phones/7925/SYSH-1.3.1.SBN alias SYSH-1.3.1.SBN
tftp-server flash:/phones/7925/TNUXH-1.3.1.SBN alias TNUXH-1.3.1.SBN
tftp-server flash:/phones/7925/WLANH-1.3.1.SBN alias WLANH-1.3.1.SBN
tftp-server flash:/phones/7906_7911/SCCP11.8-4-2S.loads alias SCCP11.8-4-2S.loads
tftp-server flash:/phones/7906_7911/term11.default.loads alias term11.default.loads
tftp-server flash:/phones/7906_7911/term06.default.loads alias term06.default.loads
tftp-server flash:/phones/7906_7911/cnu11.8-4-1-23.sbn alias cnu11.8-4-1-23.sbn
tftp-server flash:/phones/7906_7911/apps11.8-4-1-23.sbn alias apps11.8-4-1-23.sbn
tftp-server flash:/phones/7906_7911/dsp11.8-4-1-23.sbn alias dsp11.8-4-1-23.sbn
tftp-server flash:/phones/7906_7911/jar11sccp.8-4-1-23.sbn alias jar11sccp.8-4-1-23.sbn
tftp-server flash:/phones/7906_7911/cvm11sccp.8-4-1-23.sbn alias cvm11sccp.8-4-1-23.sbn
tftp-server flash:/phones/7931/SCCP31.8-4-2S.loads alias SCCP31.8-4-2S.loads
tftp-server flash:/phones/7931/cnu31.8-4-1-23.sbn alias cnu31.8-4-1-23.sbn
tftp-server flash:/phones/7931/term31.default.loads alias term31.default.loads
tftp-server flash:/phones/7931/apps31.8-4-1-23.sbn alias apps31.8-4-1-23.sbn
tftp-server flash:/phones/7931/dsp31.8-4-1-23.sbn alias dsp31.8-4-1-23.sbn
tftp-server flash:/phones/7931/jar31sccp.8-4-1-23.sbn alias jar31sccp.8-4-1-23.sbn
tftp-server flash:/phones/7931/cvm31sccp.8-4-1-23.sbn alias cvm31sccp.8-4-1-23.sbn
tftp-server flash:/phones/7941_7961/SCCP41.8-4-2S.loads alias SCCP41.8-4-2S.loads
tftp-server flash:/phones/7941_7961/term41.default.loads alias term41.default.loads
tftp-server flash:/phones/7941_7961/term61.default.loads alias term61.default.loads
tftp-server flash:/phones/7941_7961/cnu41.8-4-1-23.sbn alias cnu41.8-4-1-23.sbn
tftp-server flash:/phones/7941_7961/apps41.8-4-1-23.sbn alias apps41.8-4-1-23.sbn
tftp-server flash:/phones/7941_7961/dsp41.8-4-1-23.sbn alias dsp41.8-4-1-23.sbn
tftp-server flash:/phones/7941_7961/jar41sccp.8-4-1-23.sbn alias jar41sccp.8-4-1-23.sbn
tftp-server flash:/phones/7941_7961/cvm41sccp.8-4-1-23.sbn alias cvm41sccp.8-4-1-23.sbn
tftp-server flash:/phones/7942_7962/SCCP42.8-4-2S.loads alias SCCP42.8-4-2S.loads
tftp-server flash:/phones/7942_7962/term42.default.loads alias term42.default.loads
tftp-server flash:/phones/7942_7962/term62.default.loads alias term62.default.loads
tftp-server flash:/phones/7942_7962/cnu42.8-4-1-23.sbn alias cnu42.8-4-1-23.sbn
tftp-server flash:/phones/7942_7962/dsp42.8-4-1-23.sbn alias dsp42.8-4-1-23.sbn
tftp-server flash:/phones/7942_7962/apps42.8-4-1-23.sbn alias apps42.8-4-1-23.sbn
tftp-server flash:/phones/7942_7962/jar42sccp.8-4-1-23.sbn alias jar42sccp.8-4-1-23.sbn
tftp-server flash:/phones/7942_7962/cvm42sccp.8-4-1-23.sbn alias cvm42sccp.8-4-1-23.sbn
tftp-server flash:/phones/7945_7965/SCCP45.8-4-2S.loads alias SCCP45.8-4-2S.loads
tftp-server flash:/phones/7945_7965/term45.default.loads alias term45.default.loads
tftp-server flash:/phones/7945_7965/term65.default.loads alias term65.default.loads
tftp-server flash:/phones/7945_7965/cnu45.8-4-1-23.sbn alias cnu45.8-4-1-23.sbn
tftp-server flash:/phones/7945_7965/dsp45.8-4-1-23.sbn alias dsp45.8-4-1-23.sbn
tftp-server flash:/phones/7945_7965/apps45.8-4-1-23.sbn alias apps45.8-4-1-23.sbn
tftp-server flash:/phones/7945_7965/jar45sccp.8-4-1-23.sbn alias jar45sccp.8-4-1-23.sbn
tftp-server flash:/phones/7945_7965/cvm45sccp.8-4-1-23.sbn alias cvm45sccp.8-4-1-23.sbn
tftp-server flash:/phones/7970_7971/SCCP70.8-4-2S.loads alias SCCP70.8-4-2S.loads
tftp-server flash:/phones/7970_7971/term70.default.loads alias term70.default.loads
tftp-server flash:/phones/7970_7971/term71.default.loads alias term71.default.loads
tftp-server flash:/phones/7970_7971/cnu70.8-4-1-23.sbn alias cnu70.8-4-1-23.sbn
tftp-server flash:/phones/7970_7971/apps70.8-4-1-23.sbn alias apps70.8-4-1-23.sbn
tftp-server flash:/phones/7970_7971/dsp70.8-4-1-23.sbn alias dsp70.8-4-1-23.sbn
tftp-server flash:/phones/7970_7971/jar70sccp.8-4-1-23.sbn alias jar70sccp.8-4-1-23.sbn
tftp-server flash:/phones/7970_7971/cvm70sccp.8-4-1-23.sbn alias cvm70sccp.8-4-1-23.sbn
tftp-server flash:/phones/7975/SCCP75.8-4-2S.loads alias SCCP75.8-4-2S.loads
tftp-server flash:/phones/7975/cnu75.8-4-1-23.sbn alias cnu75.8-4-1-23.sbn
tftp-server flash:/phones/7975/term75.default.loads alias term75.default.loads
tftp-server flash:/phones/7975/apps75.8-4-1-23.sbn alias apps75.8-4-1-23.sbn
tftp-server flash:/phones/7975/dsp75.8-4-1-23.sbn alias dsp75.8-4-1-23.sbn
tftp-server flash:/phones/7975/cvm75sccp.8-4-1-23.sbn alias cvm75sccp.8-4-1-23.sbn
tftp-server flash:/phones/7975/jar75sccp.8-4-1-23.sbn alias jar75sccp.8-4-1-23.sbn
tftp-server flash:/ringtones/Analog1.raw alias Analog1.raw
tftp-server flash:/ringtones/Analog2.raw alias Analog2.raw
tftp-server flash:/ringtones/AreYouThere.raw alias AreYouThere.raw
tftp-server flash:/ringtones/DistinctiveRingList.xml alias DistinctiveRingList.xml
tftp-server flash:/ringtones/RingList.xml alias RingList.xml
tftp-server flash:/ringtones/AreYouThereF.raw alias AreYouThereF.raw
tftp-server flash:/ringtones/Bass.raw alias Bass.raw
tftp-server flash:/ringtones/CallBack.raw alias CallBack.raw
tftp-server flash:/ringtones/Chime.raw alias Chime.raw
tftp-server flash:/ringtones/Classic1.raw alias Classic1.raw
tftp-server flash:/ringtones/Classic2.raw alias Classic2.raw
tftp-server flash:/ringtones/ClockShop.raw alias ClockShop.raw
tftp-server flash:/ringtones/Drums1.raw alias Drums1.raw
tftp-server flash:/ringtones/Drums2.raw alias Drums2.raw
tftp-server flash:/ringtones/FilmScore.raw alias FilmScore.raw
tftp-server flash:/ringtones/HarpSynth.raw alias HarpSynth.raw
tftp-server flash:/ringtones/Jamaica.raw alias Jamaica.raw
tftp-server flash:/ringtones/KotoEffect.raw alias KotoEffect.raw
tftp-server flash:/ringtones/MusicBox.raw alias MusicBox.raw
tftp-server flash:/ringtones/Piano1.raw alias Piano1.raw
tftp-server flash:/ringtones/Piano2.raw alias Piano2.raw
tftp-server flash:/ringtones/Pop.raw alias Pop.raw
tftp-server flash:/ringtones/Pulse1.raw alias Pulse1.raw
tftp-server flash:/ringtones/Ring1.raw alias Ring1.raw
tftp-server flash:/ringtones/Ring2.raw alias Ring2.raw
tftp-server flash:/ringtones/Ring3.raw alias Ring3.raw
tftp-server flash:/ringtones/Ring4.raw alias Ring4.raw
tftp-server flash:/ringtones/Ring5.raw alias Ring5.raw
tftp-server flash:/ringtones/Ring6.raw alias Ring6.raw
tftp-server flash:/ringtones/Ring7.raw alias Ring7.raw
tftp-server flash:/ringtones/Sax1.raw alias Sax1.raw
tftp-server flash:/ringtones/Sax2.raw alias Sax2.raw
tftp-server flash:/ringtones/Vibe.raw alias Vibe.raw
tftp-server flash:/Desktops/CampusNight.png
tftp-server flash:/Desktops/TN-CampusNight.png
tftp-server flash:/Desktops/CiscoFountain.png
tftp-server flash:/Desktops/TN-CiscoFountain.png
tftp-server flash:/Desktops/CiscoLogo.png
tftp-server flash:/Desktops/TN-CiscoLogo.png
tftp-server flash:/Desktops/Fountain.png
tftp-server flash:/Desktops/TN-Fountain.png
tftp-server flash:/Desktops/MorroRock.png
tftp-server flash:/Desktops/TN-MorroRock.png
tftp-server flash:/Desktops/NantucketFlowers.png
tftp-server flash:/Desktops/TN-NantucketFlowers.png
tftp-server flash:Desktops/320x212x16/List.xml
tftp-server flash:Desktops/320x212x12/List.xml
tftp-server flash:Desktops/320x216x16/List.xml
tftp-server flash:/bacdprompts/en_bacd_allagentsbusy.au alias en_bacd_allagentsbusy.au
tftp-server flash:/bacdprompts/en_bacd_disconnect.au alias en_bacd_disconnect.au
tftp-server flash:/bacdprompts/en_bacd_enter_dest.au alias en_bacd_enter_dest.au
tftp-server flash:/bacdprompts/en_bacd_invalidoption.au alias en_bacd_invalidoption.au
tftp-server flash:/bacdprompts/en_bacd_music_on_hold.au alias en_bacd_music_on_hold.au
tftp-server flash:/bacdprompts/en_bacd_options_menu.au alias en_bacd_options_menu.au
tftp-server flash:/bacdprompts/en_bacd_welcome.au alias en_bacd_welcome.au
tftp-server flash:/bacdprompts/en_bacd_xferto_operator.au alias en_bacd_xferto_operator.au
snmp-server community public RO
control-plane
bridge 1 route ip
bridge 100 route ip
voice-port 0/0/0
caller-id enable
voice-port 0/0/1
caller-id enable
voice-port 0/0/2
caller-id enable
voice-port 0/0/3
caller-id enable
voice-port 0/1/0
trunk-group ALL_FXO 64
connection plar opx 700
description Configured by CCA 4 FXO-0/1/0-Custom-AA
caller-id enable
voice-port 0/1/1
connection plar 202
caller-id enable
voice-port 0/1/2
connection plar 203
caller-id enable
voice-port 0/1/3
connection plar 204
caller-id enable
voice-port 0/4/0
auto-cut-through
signal immediate
input gain auto-control -15
description Music On Hold Port
sccp local Loopback0
sccp ccm 10.1.1.1 identifier 1 version 3.1
sccp
sccp ccm group 1
associate ccm 1 priority 1
dial-peer cor custom
name internal
name local
name local-plus
name international
name national
name national-plus
name emergency
name toll-free
dial-peer cor list call-internal
member internal
dial-peer cor list call-local
member local
dial-peer cor list call-local-plus
member local-plus
dial-peer cor list call-national
member national
dial-peer cor list call-national-plus
member national-plus
dial-peer cor list call-international
member international
dial-peer cor list call-emergency
member emergency
dial-peer cor list call-toll-free
member toll-free
dial-peer cor list user-internal
member internal
member emergency
dial-peer cor list user-local
member internal
member local
member emergency
member toll-free
dial-peer cor list user-local-plus
member internal
member local
member local-plus
member emergency
member toll-free
dial-peer cor list user-national
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer cor list user-national-plus
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer cor list user-international
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer voice 1 pots
port 0/0/0
no sip-register
dial-peer voice 2 pots
port 0/0/1
no sip-register
dial-peer voice 3 pots
port 0/0/2
no sip-register
dial-peer voice 4 pots
port 0/0/3
no sip-register
dial-peer voice 5 pots
description ** MOH Port **
destination-pattern ABC
port 0/4/0
no sip-register
dial-peer voice 50 pots
description ** incoming dial peer **
incoming called-number ^AAAA$
port 0/1/0
dial-peer voice 51 pots
port 0/1/1
dial-peer voice 52 pots
port 0/1/2
dial-peer voice 53 pots
port 0/1/3
dial-peer voice 54 pots
description ** FXO pots dial-peer **
destination-pattern A0
port 0/1/0
no sip-register
dial-peer voice 55 pots
destination-pattern A1
port 0/1/1
no sip-register
dial-peer voice 56 pots
destination-pattern A2
port 0/1/2
no sip-register
dial-peer voice 57 pots
destination-pattern A3
port 0/1/3
no sip-register
dial-peer voice 2000 voip
description ** cue voicemail pilot number **
destination-pattern 100
b2bua
voice-class sip outbound-proxy ipv4:10.1.10.1
session protocol sipv2
session target ipv4:10.1.10.1
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 6 pots
description "catch all dial peer for BRI/PRI"
translation-profile incoming nondialable
incoming called-number .%
direct-inward-dial
dial-peer voice 2001 voip
description ** cue auto attendant number **
translation-profile outgoing PSTN_CallForwarding
destination-pattern 700
b2bua
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 58 pots
trunkgroup ALL_FXO
corlist outgoing call-emergency
description **CCA*North American-10-Digit*Emergency**
translation-profile outgoing OUTGOING_TRANSLATION_PROFILE
preference 5
destination-pattern 9911
forward-digits all
no sip-register
dial-peer voice 59 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 911
forward-digits all
no sip-register
dial-peer voice 60 pots
trunkgroup ALL_FXO
corlist outgoing call-local
description **CCA*North American-10-Digit*10-Digit Local**
preference 5
destination-pattern 9[2-9]..[2-9]......
forward-digits all
no sip-register
dial-peer voice 61 pots
trunkgroup ALL_FXO
description **CCA*North American-10-Digit*Service Numbers**
preference 5
destination-pattern 9[2-9]11
forward-digits all
no sip-register
dial-peer voice 62 pots
trunkgroup ALL_FXO
corlist outgoing call-national
description **CCA*North American-10-Digit*Long Distance**
preference 5
destination-pattern 91[2-9]..[2-9]......
forward-digits all
no sip-register
dial-peer voice 63 pots
trunkgroup ALL_FXO
corlist outgoing call-international
description **CCA*North American-10-Digit*International**
preference 5
destination-pattern 9011T
forward-digits all
no sip-register
dial-peer voice 64 pots
trunkgroup ALL_FXO
corlist outgoing call-toll-free
description **CCA*North American-10-Digit*Toll-Free**
preference 5
destination-pattern 91800.......
forward-digits all
no sip-register
dial-peer voice 65 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 91888.......
forward-digits all
no sip-register
dial-peer voice 66 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 91877.......
forward-digits all
no sip-register
dial-peer voice 67 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 91866.......
forward-digits all
no sip-register
dial-peer voice 68 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 91855.......
forward-digits all
no sip-register
no dial-peer outbound status-check pots
telephony-service
video
fxo hook-flash
max-ephones 40
max-dn 300
ip source-address 10.1.1.1 port 2000
auto assign 1 to 1 type bri
calling-number initiator
service phone videoCapability 1
service dnis overlay
service dnis dir-lookup
timeouts interdigit 5
system message BRAINWAVEcomms1
url services http://10.1.10.1/voiceview/common/login.do
url authentication http://10.1.10.2/CCMCIP/authenticate.asp
load 7914 S00105000300
load 7915-12 B015-1-0-3
load 7915-24 B015-1-0-3
load 7916-12 B016-1-0-3
load 7916-24 B016-1-0-3
load 7906 SCCP11.8-4-2S
load 7911 SCCP11.8-4-2S
load 7921 CP7921G-1.2.1
load 7925 CP7925G-1.3.1
load 7931 SCCP31.8-4-2S
load 7936 cmterm_7936.3-3-16-0
load 7937 apps37sccp.1-3-2-0
load 7960-7940 P00308001000
load 7941 SCCP41.8-4-2S
load 7941GE SCCP41.8-4-2S
load 7942 SCCP42.8-4-2S
load 7945 SCCP45.8-4-2S
load 7961 SCCP41.8-4-2S
load 7961GE SCCP41.8-4-2S
load 7962 SCCP42.8-4-2S
load 7965 SCCP45.8-4-2S
load 7970 SCCP70.8-4-2S
load 7971 SCCP70.8-4-2S
load 7975 SCCP75.8-4-2S
load 521G-524G cp524g-8-1-17
load 525G spa525g-7-1-9
load 501G spa5x5-7-1-3c
load 502G spa5x5-7-1-3c
load 504G spa5x5-7-1-3c
load 508G spa5x5-7-1-3c
load 509G spa5x5-7-1-3c
time-zone 5
voicemail 100
max-conferences 8 gain -6
call-forward pattern .T
call-forward system redirecting-expanded
moh flash:/media/music-on-hold.au
multicast moh 239.10.16.16 port 2000
web admin system name cisco secret 5 $1$qrWt$SxyHBmcgNuOpbHsSYexQU.
dn-webedit
time-webedit
transfer-system full-consult dss
transfer-pattern 9.T
transfer-pattern .T
secondary-dialtone 9
fac standard
create cnf-files version-stamp 7960 Feb 09 2012 00:26:13
ephone-template  15
url services 1 http://10.1.10.1/voiceview/common/login.do VoiceviewExpress
softkeys remote-in-use  Newcall
softkeys idle  Redial Newcall Cfwdall Pickup Gpickup Dnd Login
softkeys seized  Cfwdall Endcall Redial Pickup Gpickup Callback
softkeys connected  Hold Endcall Trnsfer Confrn Acct Park
button-layout 7931 2
ephone-template  16
ephone-template  17
softkeys remote-in-use  CBarge Newcall
ephone-template  18
ephone-dn  9
number BCD no-reg primary
description MoH
moh out-call ABC
ephone-dn  11  dual-line
number 203 no-reg primary
label 203
description MR MATTHEW
name MR MATTHEW
call-forward busy 100
call-forward noan 100 timeout 20
ephone-dn  17  dual-line
number 208 no-reg primary
label 208
description 208
name 208
ephone-dn  18  dual-line
number 209 no-reg primary
label 209
description 209
name 209
ephone-dn  19  dual-line
number 210 no-reg primary
label 210
description MD CEO
name MD CEO
ephone-dn  20  dual-line
number 211 no-reg primary
label 211
description 211
name 211
ephone-dn  21  dual-line
number 212 no-reg primary
label 212
description 212
name 212
ephone-dn  22  dual-line
number 213 no-reg primary
label 213
description 213
name 213
ephone-dn  23  dual-line
number 214 no-reg primary
label 214
description 214
name 214
ephone-dn  24  dual-line
number 215 no-reg primary
label 215
description 215
name 215
ephone-dn  25  dual-line
number 216 no-reg primary
label 216
description 216
name 216
ephone-dn  26  dual-line
number 217 no-reg primary
label 217
description 217
name 217
ephone-dn  27  dual-line
number 218 no-reg primary
label 218
description 218
name 218
ephone-dn  28  dual-line
number 219 no-reg primary
label 219
description 219
name 219
ephone-dn  29  dual-line
number 220 no-reg primary
label 220
description 220
name 220
ephone-dn  30  dual-line
number 221 no-reg primary
label 221
description 221
name 221
ephone-dn  31  dual-line
number 222 no-reg primary
label 222
description 222
name 222
ephone-dn  32  dual-line
number 223 no-reg primary
label 223
description 223
name 223
ephone-dn  33  dual-line
number 224 no-reg primary
label 224
description 224
name 224
ephone-dn  34  dual-line
number 225 no-reg primary
label 225
description 225
name 225
ephone-dn  35  dual-line
number 226 no-reg primary
label 226
description 226
name 226
ephone-dn  36  dual-line
number 227 no-reg primary
label 227
description 227
name 227
ephone-dn  37  dual-line
number 228 no-reg primary
label 228
description 228
name 228
ephone-dn  38  dual-line
number 229 no-reg primary
label 229
description 229
name 229
ephone-dn  39  dual-line
number 230 no-reg primary
label 230
description 230
name 230
ephone-dn  40  dual-line
number 231 no-reg primary
label 231
description 231
name 231
ephone-dn  41  dual-line
number 232 no-reg primary
label 232
description 232
name 232
ephone-dn  42  dual-line
number 233 no-reg primary
label 233
description 233
name 233
ephone-dn  43  dual-line
number 234 no-reg primary
label 234
description 234
name 234
ephone-dn  44  dual-line
number 235 no-reg primary
label 235
description 235
name 235
ephone-dn  45  dual-line
number 236 no-reg primary
label 236
description 236
name 236
ephone-dn  293  dual-line
number 207 no-reg primary
pickup-group 1
label 207
description MARKETTING
name MARKET TING
ephone-dn  294  dual-line
number 202 no-reg primary
label 202
description CONFERENCE ROOM
name CONFERENCE ROOM
ephone-dn  295  dual-line
number 205 no-reg primary
label 205
description DR DOGO
name DR DOGO
ephone-dn  296  dual-line
number 206 no-reg primary
label 206
description ENGINEERS OFFICE
name ENGINEERS OFFICE
ephone-dn  297  dual-line
number 204 no-reg primary
pickup-group 1
label 204
description OFFICE MANAGER
name OFFICE MANAGER
ephone-dn  298  dual-line
number 201 no-reg primary
pickup-group 1
label 201
description RECEPTION
name RECEP TION
ephone-dn  299
number A801... no-reg primary
mwi off
ephone-dn  300
number A800... no-reg primary
mwi on
ephone  1
device-security-mode none
mac-address E8B7.4816.5562
ephone-template 16
max-calls-per-button 2
username "MARKETTING" password 123456
type 504G
button  1:293
ephone  2
mac-address E8B7.4816.5571
ephone-template 16
username "ENGR" password 123456
type 504G
button  1:296
ephone  3
mac-address E8B7.4816.5432
ephone-template 16
username "MRMATTHEW" password 123456
type 504G
button  1:11
ephone  4
mac-address E8B7.4816.541B
ephone-template 16
username "MD" password 123456
type 504G
button  1:19
ephone  5
mac-address E8B7.4816.532F
ephone-template 16
username "OFFICEMGR" password 123456
type 504G
button  1:297
ephone  9
video
mac-address 0004.F2ED.5617
ephone-template 16
username "CONFROOM" password 123456
type 7937
button  1:294
ephone  10
mac-address E8B7.4816.53F1
ephone-template 16
username "RECEPTION" password 123456
type 504G
button  1:298
ephone  11
mac-address E8B7.4816.5414
ephone-template 16
username "DRDOGO" password 123456
type 504G
button  1:295
banner login ^CCisco Configuration Assistant. Version: 3.1 (1). Sat Feb 04 14:09:09 WAT 2012^C
alias exec cca_voice_mode PBX
line con 0
no modem enable
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
line vty 5 100
ntp master
end
command completed.
Akwu Sani Mon, 02/13/2012 - 14:08
thanks for your post, my company just got a uc540 and needs it integrated in our existing network. The existing network is such that internet enters into smoothwall firewall which is also the dhcp server. the smooth wall inside netwrok interface goes into a cisco switch from where users connect. I unplugged the lan leg of the smoothwall from the switch and connected it to the uc540 wan portand then connected the expansion port on the uc to the switch. I then disabled dhcp on the uc as i expect that users will get IP from the smoothwall but that is not happening.
pls anyone with a way out?
