Warning message
power consumption
I have 2 x 3560e-24td-s
          2 x ASA5510
          2 x 2821(no modules)
          2 x 2901
I'm trying to figure out power draw in Amps for my new cabinet.
I looked at the data sheet for the 2821 and it says 3A for the 110V under the row
AC Input Current
Would that be accurate if I did that for all the models and then just added up the total?
chris
Reza Sharifi Thu, 01/05/2012 - 12:05
  • Cisco Designated VIP,
    2017 LAN
Hi Chris,
You would need to look at each device's data sheet to get more accurate number, specially if the any of your switches have POE ports.
Related Content
