AIM-CUE module
Jan 6th, 2012
I have installed an AIM-CUE into my 2801 router, but there are some files which am not sure which will work with this AIM-CUE which l have installed into the router 2801. These are files that l have and l need an advise concerning these files because l have the nme and the aim files but the device that l have installed into my router 2801 is AIM-CUE. Advice me on which ones to use pls.
Ojay
1 cue-installer.nme.7.0.3
2 cue-vm-installer-k9.nme.7.0.3.prt1
3 cue-vm-k9.nme.7.0.3pkg
4 cue-vm-licence_50mbx_ccm_7.0.3pkg
5 cue-vm-en_US-langpack.nme.7.0.3prt1
6 cue-vm-full-k9.nme.7.0.3.prt1
7 cue-vm-langpack.nme.7.0.3.pkg
8 cue-installer.nm-aim.7.0.3
Rob Huffman Fri, 01/06/2012 - 05:39
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Ojay,
Here we go
For NM-CUE, NM-CUE-EC, and AIM-CUE (cue-vm-k9.nm-aim.7.0.x.zip)
cue-installer.nm-aim.7.0.x
cue-vm-k9.nm-aim.7.0.x.pkg
cue-vm-full-k9.nm-aim.7.0.x.prt1
cue-vm-installer-k9.nm-aim.7.0.x.prt1
cue-vm-langpack.nm-aim.7.0.x.pkg
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel7_0/install/boothelp.html#wp1142398
And;
cue-vm-en_US-langpack.nm-aim.7.0.6.prt1
Release Date: 05/OCT/2010
Package payload containing all US English language data and prompt files associated with the Cisco Unity Express with VoiceMail application on the AIM-CUE, NM-CUE, and NM-CUE-EC service modules.
Size: 27537.68 KB (28198577 bytes)
Cheers!
Rob
Please remember to tag your threads and help support "Teachers without Borders"
https://supportforums.cisco.com/community/netpro/idea-center/communityhelpingcommunity
