Problems with MTU when using gre o/ ipsec on pppoe connection
Jan 6th, 2012
Im having some problems with a DMVPN connection on a Cisco 876.
It is connected to an ADSL line with PPPoE dialer.
The pppoe is 8 byte overhead and the DMVPN is 24 byte, which should be 1468 MTU.
However, i also have configured ipsec tunnel mode (default ios) on this and because of ipsec im having troubles doing the mtu math for max MTU on packets leaving/received on the tunnel interface. Configuration is as follow:
interface Tunnel xx
ip address x.x.x.x x.x.x.x
ip nhrp authentication xxxx
ip nhrp map multicast x.x.x.x
ip nhrp map x.x.x.x x.x.x.x
ip nhrp network-id 10
ip nhrp holdtime 300
ip nhrp nhs x.x.x.x
ip virtual-reassembly
tunnel source DialerX
tunnel mode gre multipoint
tunnel key xxxxx
tunnel protection ipsec profile vpnprof
crypto isakmp policy 1
authentication pre-share
crypto isakmp key xxxxxxx address x.x.x.x x.x.x.x
crypto ipsec transform-set dmvpn-trans esp-3des esp-sha-hmac
crypto ipsec profile vpnprof
set transform-set dmvpn-trans
  1. How much MTU is max size i can get through here?
  2. And what would the optimal mtu be here?
  3. Should the Dialer interface be configured with any ip mtu at all? Its configured with "ip mtu 1492" in my configuration.
  4. Also, any good optimal tcp adjust-mss size?
Any help would be appreciated!
Kristian Brown
Marcin Latosiewicz Fri, 01/06/2012 - 05:35
  • Cisco Employee,
Kristian,
Typically DMVPN tunnel MTU is set to 1400 for connections with around 1500 byte MTU.
MSS = MTU - 40 (no IP options) = 1360 in that case.
Also - if possible use transport mode for your DMVPN tunnel, IOS is smart enough to fallback from transport to tunnel when needed and you will save a few bytes ;-)
Marcin
