Multiple extensions on one phone
Answered Question
Jan 6th, 2012
I've got a client who has more employees than phones.
Is there a way to assign multiple extensions to one phone?
John
Correct Answer by juliomar about 5 years 3 months ago
Hi John,
You can create additional extensions to a phone, then label them according to the user.  However, the Internal Directory will only list the main extension's user.
See example of this here:
https://supportforums.cisco.com/message/3500728#3500728
Cheers,
Julio
Overall Rating: 5 (1 ratings)
rsawyer6003 Sun, 01/08/2012 - 17:52
if there are more extensions than phones I assume you are just needing voicemail for each employee? If that is the case you create users with assigned extensions and voicemail boxes. Then set up a cheap spa301 in a common area. Now each employee without a phone can check voicemail at the 301 by dialing the vm pilot, press * then follow prompts to check vm. Or you could do voicemail to email.
John Hoyt Wed, 01/11/2012 - 08:18
Thanks Ryan for the input... I went with Julio's suggestion and I think the client is indeed happy... We'll know soon!
