Warning message
Troubleshoting BGP and static router
Jan 6th, 2012
I have a router connected to internet with bgp routing , my router connect to my firewall with static route , strangely from outside/internet they can access my dmz/public server, but from inside i cant ping my ip public server. i believe this is not acl issue but routing issue ?
INTERNET
ROUTER
FIREWALL  --------- DMZ
CORE
my router config :
interface GigabitEthernet0/0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
duplex auto
speed auto
media-type rj45
no mop enabled
interface GigabitEthernet0/0.3628
encapsulation dot1Q 3628
ip address 192.168.129.78 255.255.255.252
no cdp enable
interface GigabitEthernet0/0.3629
encapsulation dot1Q 3629
ip address 192.168.129.82 255.255.255.252
no cdp enable
interface GigabitEthernet0/1
no ip redirects
no ip unreachables
no ip proxy-arp
duplex auto
speed auto
media-type rj45
no mop enabled
router bgp 65100
no synchronization
bgp log-neighbor-changes
network 118.97.126.0 mask 255.255.255.192
neighbor 192.168.129.77 remote-as 17974
neighbor 192.168.129.77 description LOCAL
neighbor 192.168.129.77 soft-reconfiguration inbound
neighbor 192.168.129.81 remote-as 17974
neighbor 192.168.129.81 description GLOBAL
neighbor 192.168.129.81 soft-reconfiguration inbound
no auto-summary
ip forward-protocol nd
ip route 10.100.0.0 255.255.224.0 118.97.126.62
ip route 118.97.126.0 255.255.255.192 118.97.126.62
ip route 172.16.0.0 255.255.0.0 118.97.126.62
ip route 192.168.0.0 255.255.0.0 118.97.126.62
ip route 192.168.100.0 255.255.255.0 118.97.126.62
my firewall config :
nameif outside
security-level 0
ip address 118.97.126.62 255.255.255.252
nameif inside
security-level 100
ip address 172.16.100.2 255.255.255.252
interface GigabitEthernet0/2
nameif dmz
security-level 0
ip address 192.168.0.254 255.255.255.0
interface GigabitEthernet0/3
nameif dmz-2
security-level 0
ip address 192.168.100.254 255.255.255.0
icmp unreachable rate-limit 1 burst-size 1
icmp permit any outside
icmp permit 118.97.126.0 255.255.255.192 outside
icmp permit 172.16.0.0 255.255.0.0 inside
icmp permit 192.168.0.0 255.255.255.0 dmz
icmp permit 192.168.100.0 255.255.255.0 dmz-2
icmp permit 10.100.0.0 255.255.224.0 dmz-2
icmp permit 172.16.30.0 255.255.255.0 management
route outside 0.0.0.0 0.0.0.0 118.97.126.61 1
route inside 10.2.0.0 255.255.0.0 172.16.100.1 1
route inside 10.3.0.0 255.255.0.0 172.16.100.1 1
route inside 10.6.0.0 255.255.0.0 172.16.100.1 1
route dmz-2 10.8.8.1 255.255.255.255 192.168.100.140 1
route dmz-2 10.100.0.0 255.255.224.0 Cisco-Wifi-Gateway 1
route inside 172.16.0.0 255.255.0.0 172.16.100.1 1
jefsims Sat, 01/07/2012 - 05:17
Hi Ibrahim,
To clarify, your trying to ping from a end-host say a desktop PC, to your server that lives in the DMZ?
For example:
F/W-------(DMZ)------> SERVER
CORE
END-HOST
From reading the details though:
You have these static routes in place for 192.168.X.X to 118.97.126.62 and 192.168.100.X via the same IP?
Further reading it suggests your pushing those routes at your firewall which protects your LAN and DMZ and appears to be an ASA or ASR device
Question(s) posed:
1. Have you checked there is a route present for internal corporate users to access the DMZ?
- I'm not 100% on firewall software however in the IOS world it would be 'show ip route X.X.X.X' (changing X.X.X.X for the IP of the box your trying to reach).
2. Have you put in place an ACL that permits the corporate LAN users to reach those devices within the DMZ?
-- You should be able to confirm this by seeing the hits on the ACL
3. Are you sure the firewall is correctly configured to handle the packets coming at it from both sides?
-- You would need to check this with the firewall forums to make sure it's configured properly.
4. Do you have a traceroute (tracert for windows) from the box your testing to the server in question? This will tell you where the issue lies as the last hop will give you an idea of where to start looking.
Let me know how you get on.
Jeff
superlubis Sat, 01/07/2012 - 19:51
- my internal/END-HOST can ping my dmz server with their local IP(192.168.0.x & 192.168.100.x), but my end-host cant ping my dmz server with their nat public ip ( 118.97.126.x )
- my dmz server can ping their ip local IP(192.168.0.x & 192.168.100.x), but my dmz server cant ping their nat/public ip
( 118.97.126.x )
- internet user can ping my dmz public ip
in my firewall :
route outside 0.0.0.0 0.0.0.0 118.97.126.61 1  <--- route all ip to router ip
in my router :
ip route 118.97.126.0 255.255.255.192 118.97.126.62 <-- route 118.97.126.0/26 to firewall outside.
jefsims Sat, 01/07/2012 - 20:58
So, to clarify...
118.97.126.x is your public IP and it lives on the router that is above the firewall in the diagram you drew?
This does not seem like a BGP problem at all. It seems more like an issue with your ACL/Firewall configuration. Can you provide a traceroute from both directions to see where the packets flow to?
This will tell us where the problem is and can start pointing you in the right direction.
Kind Regards,
Jeff
