CUCM 8.6 ISO
Answered Question
Jan 7th, 2012
I wanna download a ISO image for fresh install of CUCM 8.6 on UCS, I have ordered the Kit but not yet delivered. Before going live i want to test in the lab environment. I have read many thread that there is no download  ISO for the 8.6, Either it should it come from cisco or upgrade from 6.X or 7.x by upgrade patch. cmterm-devicepack8.6.1.21019-1.cop.sgn
If i m correct please route me to the download page where i can get the ISO bootable for 6.X or 7.X
Tx
Correct Answer by Jaime Valencia about 2 years 3 months ago
And also, if you mean that cmterm-devicepack8.6.1.21019-1.cop.sgn is meant for the upgrade it IS NOT, this is not an upgrade file. As the name clearly says, it's a device pack
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
Correct Answer by Chris Deren about 2 years 3 months ago
If this is for lab only you could edit the ISO and make it bootable, I am sure you can find threads on it here or google for it,
Chris
Correct Answer by Paolo Bevilacqua about 2 years 3 months ago
As you have read before.
There are no ISO bootlable CM downloads by Cisco.
Average Rating: 5 (3 ratings)
Correct Answer
Paolo Bevilacqua Sat, 01/07/2012 - 06:37
Correct Answer
Chris Deren Sat, 01/07/2012 - 07:29
Chris
Correct Answer
Jaime Valencia Sat, 01/07/2012 - 08:06
java
lambay2000 Sat, 01/07/2012 - 11:06
I won't get  ISO image for 6.X or 7.X also??????. IF NO  THEN can anybody route me to the upgrade patch of 8.6 from 6.X or 7.x atleast.
Tx
Rob Huffman Sun, 01/08/2012 - 06:40
Hi Lambay,
Have a look at this thread with a link to Michael's blog in it he
explains how to make a bootable .iso for lab purposes;
https://supportforums.cisco.com/message/3059280#3059280
Then to download the 8.6 patch file;
CCO
Tools and Resources
Software Downloads
Unified Communications Manager / Cisco Unity Connection Updates-8.6(2a)
via
http://www.cisco.com/cisco/software/navigator.html
Cheers!
Rob
Login or Register to take actions
Posted January 7, 2012 at 4:54 AM
Stats:
Replies:6 Avg. Rating:5
Views:9754 Votes:0
Shares:0
Tags: No tags.
Discussions Leaderboard
