Basic clarification on QoS - EF - VoIP
Jan 7th, 2012
Imagine you have SIP trunking services and 3 sites connected via ISP MPLS.
Then Branch1 bandwidth is T1. Gold CAR in place is 340K (it supports therefore 10 concurrent calls, G.729 as per provider confirmation). Assume no burst mechanism has been enabled.
Question:
a)What happens if phone users on Branch1 place 11 concurrent calls? Is the 11th call going to be dropped? Does it depend on the PE policing policies regarding how the EF traffic is treated? Please advise.
lgijssel Sun, 01/08/2012 - 01:05
  • Red, 2250 points or more
When the bandwidtg is exceeded, the policer kicks in.
This means traffic from all active session will become subject to packet loss.
Depending on your PBX, it may be possible to set a limit to the number of concurrent VOIP calls.
In this case, the 11th call would be routed over PSTN if available or have its call setup denied.
You cannot configure this kind of setting on the router as it has no knowledge about phone conversations, only about IP.
regards,
Leo
Joseph W. Doherty Mon, 01/09/2012 - 06:26
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
What exactly happens depends on how QoS polices are defined on your devices, whether there's interface congestion, and your MPLS provider's bandwidth enforcement policies.
Generally, assume you'll be limited to agreed bandwidth.  This limitation is usually "global", i.e. not just the 11th call flow would be impacted, but all 11 calls might be impacted.
Ideally, as Leo noted, some systems will track number of calls and block new calls that would over subscribe your allocated bandwidth.  As an alternative, I have had some luck by marking down oversubscribed traffic, but your mileage might vary.
PS;
BTW, when working with compressed CODECs, you should allow for transitory bandwidth spikes.
