Unity Express 7.4.1 and CUCM 8.5.1
Jan 9th, 2012
I looked in Compatibility Matrix for Unity Express and found that Unity Express 7.4.1 and Callmanager 8.5.1 wll work together.
Now I upgraded Unity Express to version 7.4.1. I read the CTI-ports via Unity Web GUI from CUCM and it found right the ports.
But in CUCM the ports doesnt register with unity express.
What could I do to register the ports? The jtapi user already associated with the ports and I also reset the password t both systems.
Is there a trace I could switch on for port registration?
Support Albakom Wed, 01/11/2012 - 04:54
meanwhile i found why not register, at the CTI are securty profile configured. after remove it, the ports register but still doesnt work:
A debug at the CLI of CUE show following if someone call the Routepoint with DN 9002:
Jan 10 10:19:09 localhost java:    INFO ccn SubsystemJtapi DBUG CTIPG_ROUTE_EVENT:CTI Port Group route event: Route Session=[9002:PT_Alle:1/(P1-unity) GCID=(1,7648)->ACTIVE]->OFFERED,Route Address=9002,Failure reason=Terminate Route Connection,Exception=com.cisco.channel.ChannelLicenseViolationException: license limit
Jan 10 10:19:09 localhost java:    INFO ccn SubsystemJtapi DBUG EXCEPTION:com.cisco.channel.ChannelLicenseViolationException: license limit exceeded for application type: AAWorkflowPrivilege
Jan 10 10:19:09 localhost java:    INFO ccn SubsystemJtapi DBUG EXCEPTION:      at com.cisco.contact.impl.ContactStubImpl.addChannels(ContactStubImpl.java:1667)
Jan 10 10:19:09 localhost java:    INFO ccn SubsystemJtapi DBUG EXCEPTION:      at com.cisco.channel.impl.ChannelManagerImpl.getFromDifferentClassGroups(ChannelManagerImpl.java:950)
Jan 10 10:19:09 localhost java:    INFO ccn SubsystemJtapi DBUG EXCEPTION:      at com.cisco.channel.impl.ChannelManagerImpl.getIdleChannels(ChannelManagerImpl.java:686)
Jan 10 10:19:09 localhost java:    INFO ccn SubsystemJtapi DBUG EXCEPTION:      at com.cisco.channel.Group.getIdleChannels(Group.java:305)
Jan 10 10:19:09 localhost java:    INFO ccn SubsystemJtapi DBUG EXCEPTION:      at com.cisco.wf.subsystems.jtapi.TAPIPortGroup$RouteCallObserver$1.run(TAPIPortGroup.java:17573)
Jan 10 10:19:09 localhost java:    INFO ccn SubsystemJtapi DBUG EXCEPTION:      at com.cisco.executor.impl.ParallelExecutorImpl$WorkOrder.run(ParallelExecutorImpl.java:283)
Jan 10 10:19:09 localhost java:    INFO ccn SubsystemJtapi DBUG EXCEPTION:      at com.cisco.executor.impl.WorkerPool$Worker.run(WorkerPool.java:398)
Jan 10 10:19:09 localhost java:    INFO ccn SubsystemJtapi DBUG EXCEPTION:      at java.lang.Thread.run(Thread.java:595)
Anybody knows what this license violence means? The licenses are valid and activ.
Jorge Armijo Wed, 01/11/2012 - 06:13
  • Silver, 250 points or more
Hi!
Can You pelease provide the show run, show ccn application, show ccn trigger and show tech of the CUE? Also did you tried to configure any other ccn application on the CUE? What happen if You try that?
Jorge
Related Content
