01-09-2012 09:11 PM - edited 03-21-2019 05:10 AM
Does anyone know if it is possible to use this combination and how? Can't find anything re a 508G on the plantronic support site, and the 50x support guide does not really describe anything about this, just refers to plantronics website.
Thanks.
01-16-2012 06:54 AM
I don't think the 508 supports bluetooth pairing, but you can plug wired headsets into it.
Se if this doc helps,
https://supportforums.cisco.com/docs/DOC-9926
and this one
01-17-2012 06:38 AM
Hi Mogens,
I'm not familiar with the Plantronics C65. I searched and found this page which says that the device registers as a DECT handset using GAP:
http://www.landlinephones.co.uk/product.php?pinf=988-5--Plantronics_C65_DECT_wireless_headset--
The SPA508G does not have a DECT base station so cannot support this particular handset.
Patrick
