01-10-2012 03:16 AM - edited 03-16-2019 08:54 AM
my company began the transition from alcatel device to cisco CME. I activate a central syslog server for all of our cisco device, switch router and firewall. I also log everything appen on CME. In the report log i found a perseverant call attempt. This is an exctract from the log:
Today 11:00:28,"LOCAL7","NOTICE","cisco-cm-uc520","39621:","","Syslog"," 039672: Jan 10 11:00:23.742: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:01/10/2012 11:00:23.690,cgn:BCD,cdn:,frs:0,fid:22237,fcid:BF56943E3AA811E19BBDD16C1C94F3B1,legID:56DD,bguid:BF56943E3AA811E19BBDD16C1C94F3B1" |
Today 11:00:28,"LOCAL7","NOTICE","cisco-cm-uc520","39620:","","Syslog"," 039671: Jan 10 11:00:23.742: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 1, ConnectionId BF56943E3AA811E19BBDD16C1C94F3B1, SetupTime 11:00:23.692 CET Tue Jan 10 2012, PeerAddress BCD, PeerSubAddress , DisconnectCause 1C , DisconnectText invalid number (28), ConnectTime 11:00:23.742 CET Tue Jan 10 2012, DisconnectTime 11:00:23.742 CET Tue Jan 10 2012, CallOrigin 2, ChargedUnits 0, InfoType 2, TransmitPackets 0, TransmitBytes 0, ReceivePackets 0, ReceiveBytes 0" |
Today 10:59:58,"LOCAL7","NOTICE","cisco-cm-uc520","39619:","","Syslog"," 039670: Jan 10 10:59:53.741: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:01/10/2012 10:59:53.689,cgn:BCD,cdn:,frs:0,fid:22236,fcid:AD74D1A73AA811E19BB9D16C1C94F3B1,legID:56DC,bguid:AD74D1A73AA811E19BB9D16C1C94F3B1" |
Today 10:59:58,"LOCAL7","NOTICE","cisco-cm-uc520","39618:","","Syslog"," 039669: Jan 10 10:59:53.741: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 1, ConnectionId AD74D1A73AA811E19BB9D16C1C94F3B1, SetupTime 10:59:53.691 CET Tue Jan 10 2012, PeerAddress BCD, PeerSubAddress , DisconnectCause 1C , DisconnectText invalid number (28), ConnectTime 10:59:53.741 CET Tue Jan 10 2012, DisconnectTime 10:59:53.741 CET Tue Jan 10 2012, CallOrigin 2, ChargedUnits 0, InfoType 2, TransmitPackets 0, TransmitBytes 0, ReceivePackets 0, ReceiveBytes 0" |
Today 10:59:28,"LOCAL7","NOTICE","cisco-cm-uc520","39617:","","Syslog"," 039668: Jan 10 10:59:23.740: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:01/10/2012 10:59:23.688,cgn:BCD,cdn:,frs:0,fid:22235,fcid:9B930F103AA811E19BB5D16C1C94F3B1,legID:56DB,bguid:9B930F103AA811E19BB5D16C1C94F3B1" |
Today 10:59:28,"LOCAL7","NOTICE","cisco-cm-uc520","39616:","","Syslog"," 039667: Jan 10 10:59:23.740: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 1, ConnectionId 9B930F103AA811E19BB5D16C1C94F3B1, SetupTime 10:59:23.690 CET Tue Jan 10 2012, PeerAddress BCD, PeerSubAddress , DisconnectCause 1C , DisconnectText invalid number (28), ConnectTime 10:59:23.740 CET Tue Jan 10 2012, DisconnectTime 10:59:23.740 CET Tue Jan 10 2012, CallOrigin 2, ChargedUnits 0, InfoType 2, TransmitPackets 0, TransmitBytes 0, ReceivePackets 0, ReceiveBytes 0" |
Today 10:58:59,"LOCAL7","NOTICE","cisco-cm-uc520","39615:","","Syslog"," 039666: Jan 10 10:58:53.740: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:01/10/2012 10:58:53.688,cgn:BCD,cdn:,frs:0,fid:22234,fcid:89B14D123AA811E19BB1D16C1C94F3B1,legID:56DA,bguid:89B14D123AA811E19BB1D16C1C94F3B1" |
normally the fields cgn:,cdn: and the field PeerAddress contain the source number of the call. As you can see in my log this value are set to bcd and BCD. What BCD stands for ? I look in cisco docs but i don't find anything about this BCD. I look also in my running and startup config but there's no trace of BCD.
Thanks in advance
01-10-2012 03:58 AM
BCD is just a 'special' number used by the default external MoH configuration. That in you case may be incomplete or not working. You will see it if you do "show run".
01-11-2012 02:52 AM
Thanks for the reply
i've checked the Moh configuration and it's fine and working, but the log message still appear every 20 seconds in my log. I've reconfigured the Moh following the cisco documentation but this message still appear. I can't understand the meaning of the log entry. There's some docs that can help me understand this ?
Thanks in advance.
01-11-2012 04:42 AM
Please read message above.
01-11-2012 05:59 AM
so it's right that in the log i see a call from BCD starts when nobody are using the cme ?
Thanks in advance.
01-11-2012 07:38 AM
If you could please read the message above and do what's indicated there.
