CAD set agent to ready state on startup?
Jan 10th, 2012
  • Bronze, 100 points or more
Hi All,
Is there a way to force the agents to be set in ‘Ready’ when they load CAD? Rather than them having to load CAD then click the icon to make themselves ready?
We are using UCCX 8.5.
Thanks in advance.
Matty
Chris Deren Tue, 01/10/2012 - 04:43
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
Matty,
This question used to be asked quite often few years back, and all replies indicated this was never possible, I doubt anything has changed.
HTH,
Chris
Gajanan Pande Tue, 01/10/2012 - 05:02
  • Cisco Employee,
Agent MUST go ready manually for the first time ( post login to CAD ), after that going to ready automatically from not-ready/wrap up can be controlled from workflow.
Pls rate the post if it helps.
GP.
Related Content
