Remote VPN with 5 Inside Networks
Answered Question
Jan 10th, 2012
Hello I have Cisco asa 5505 Security Adaptive
Here is My Sceniorio
ASA
Outside Interface  Eth0/0 -  155.155.155.x
Inside Network -  Eth0/1  192.168.1.1
Eth0/2          192.168.2.1
Eth0/3          192.168.3.1
Eth0/4          192.168.4.1
Eth0/5          192.168.5.1
VPN POOL ADDRESS =   10.10.10.1  ---- 10.10.10.10
So iam using Shrew Soft VPN Software  , so i want to access all these networks by a remote VPN Access , so please can any one give me a helpfull refer or link , or give an idea how i can route this networks
Sorry I might be confusing the issue here is your ASA config actually:-
Eth0/2          192.168.2.1
Eth0/3          192.168.3.1
Eth0/4          192.168.4.1
Eth0/5          192.168.5.1
if so - then there is no need to a layer 3 device, the ASA can be the Payer 3 device if all the above networks are directly connected.
Overall Rating: 5 (1 ratings)
ThomasMull9000 Wed, 01/11/2012 - 00:52
Thank's Andrew
So here i created a Remote VPN - and i give IP pool similiar to my First network 192.168.1. 10   -20
So i can reach only for the first network of 192.168.1.0
So how i can reach all other 4 networks
You just need to define the IP subnets in the split tunnel list if you have configured one, or they should already be reachable if you have configured tunnel all.  And you must make sure the ASA has a route to the layer 3 device handling the other subnets, and the other subnet devices have the layer 3 routing device as the default gateway.  The layer 3 device also needs a route for the 10.10.10.z subnet is via the ASA.
HTH>
ThomasMull9000 Wed, 01/11/2012 - 05:21
Thank's Andrew This is what iam lookin for .so i need to put a Cisco Layer 3 Switch , and add a static route for the asa .
ThomasMull9000 Wed, 01/11/2012 - 05:22
Please can you refer me , a link of how layer 3 and asa work togher
Thank You very much
Correct Answer
Eth0/2          192.168.2.1
Eth0/3          192.168.3.1
Eth0/4          192.168.4.1
Eth0/5          192.168.5.1
ThomasMull9000 Wed, 01/11/2012 - 05:40
Goood ..Thanks
So only thing i need is to get a license that supports more vlans
becuase my current license supports only 3 Vlans DMZ restricted
so in order to create all this networks i have to get security plus license that allows me to create 20 vlans
ThomasMull9000 Wed, 01/11/2012 - 23:30
i got today a new CISCO LAYER 3 Switch .. so here is my scenrio
Cisco Asa 5505
I
Outside  == 155.155.155.x
Inside  =      192.168.7.1
VPN POOL Address =   10.10.10.1   -   10.10.10.20
Layer 3 Switch Config
Vlan 2
interface ip address =  192.168.1.1
Vlan 2
interface ip address =  192.168.2.1
Vlan 2
interface ip address =  192.168.3.1
Vlan 2
interface ip address =  192.168.4.1
Vlan 2
interface ip address =  192.168.5.1
ip Routing
So i want My Remote Access VPN clients to access all this Networks. So Please can you give me a helpfull trick or Link to configure the rest of my routing
Thanks You very Much Andrew
the interface that connects to the asa should be in a vlan. Then create all the other vlans that you need so
***ASA***
Vlan 7
192.168.7.254/24
Route inside 192.168.0.0/16 q192.168.7.240
***Switch***
Vlan 7
192.168.7.240/24
Vlan 1
192.168.1.240/24
Vlan 2
192.168.2.240/24
Vlan 3
192.168.3.240/24
Vlan 4
192.168.4.240/24
Vlan 5
192.168.5.240/24
Ip default-gateway 192.168.7.259
ip addresses etc are just an idea, but you get the idea.
Related Content
